How to install a sound processor?
Old Apr 13, 2009 | 04:45 PM
tsxenthusiast's Avatar
5th Gear
Currently, I have a 2004 Acura TSX with navi and I am wanting to add on a sound processor before I add on my amps. Question is, what do I connect into the imputs of the sound processor? Here is an example of a processor that I am looking at, http://www.crutchfield.com/p_136441D...eep.html?tp=84
Since the TSX has a factory crossover in the front for the factory tweeters and midrange, which wires do I run into the processor for the front imput?
Old Apr 13, 2009 | 05:01 PM
Tsx536's Avatar
Rep'n Taxbrain.com
The crossover is actually built into the factory amp. Since you are installing your own amps, you'll be bypassing the factory amps.
You're going to be grabbing the output from the Factory HU and feeding the wires into the JL Cleansweep. Then at that point, you'll feed the signals to your factory amps via RCA.
Old Apr 13, 2009 | 05:05 PM
5th Gear
Is it a pain to remove the HU?
Old Apr 13, 2009 | 07:57 PM
mercman's Avatar
You don’t need the clean sweep; you can take the output from the Premium HU right back to any amp with balanced inputs (like the JLs) and your good to go. The Premium HU has no EQ or volume based Bass cut/boast, all the EQ is in the amp. Adding the clean sweep will add another A/D and D/A conversion and just degrade the signal.
I make a 12ft harness that plus in behind the “not an ashtray” thing. You don’t have to pull out the HU.
Check the FAQs for info on accessing the factory amp and the connectors.
Put the clean sweep budget into your speakers and amps.
PM me if you need a harness.
Jeff
Feb 25, 2020 09:57 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
james357
Feb 13, 2016 02:37 PM
Iain MacLeod
Sep 17, 2015 01:01 PM
Skirmich
Sep 15, 2015 06:41 PM
