HOTHOTHOT please fill me in!
Old Sep 3, 2002 | 12:50 PM
23wt's Avatar
Mugen Racing Team
Is is normal for my amp to heat up to the point that i don't wanna touch it? i was checking it out today and found it quite hot after playing... the my kenwood amp has a little triangle red light above the "W". When i turn the bass up to pound hard... each pound tends to make the red light dim alittle... anyone can help me out with this?
Old Sep 3, 2002 | 10:57 PM
SilverKnight's Avatar
Retired. Not available.
Sounds like you overload your amp. Turn the gain control (on the amp) down and take it easy with the volumn (head unit)
Old Sep 3, 2002 | 11:12 PM
23wt's Avatar
Mugen Racing Team
alright thanks...
Old Sep 3, 2002 | 11:16 PM
23wt's Avatar
Mugen Racing Team
it other words don't push it so hard right....? i have volume up 50%... tre full.. and bass 4 - full depending on how i feel that day.. and my amp is turned 50%
Old Sep 4, 2002 | 01:38 AM
Austin519's Avatar
23wt:
Amps do get hot...that happens, especially with passively cooled amps. Is your amp cutting out or distorting? If not you're ok on the overloading (clipping) front. Have you given it a nice thick + and gnd cable? If so then your light dimming problem is probably not wiring. It may be just power consumption...though if you only have that one 350W amp I seriously doubt it. I'd check the wiring for that light dimming issue. And never bring the amp's gain over 75%.
Austin519
Old Sep 4, 2002 | 08:29 AM
23wt's Avatar
Mugen Racing Team
thanks, i gonna check it out
Old Sep 4, 2002 | 03:32 PM
23wt's Avatar
Mugen Racing Team
thanks for all the input.. since me new to sound systems... anything else that i should beaware of?
Old Sep 5, 2002 | 12:55 PM
Slooo97CL's Avatar
Get some air circulation too...get a couple fans hook them up maybe this would help some.
Old Sep 6, 2002 | 08:28 AM
23wt's Avatar
Mugen Racing Team
couple of fans??
Old Sep 6, 2002 | 10:18 PM
Yeah, like the ones in my trunk
Old Sep 7, 2002 | 12:26 AM
23wt's Avatar
Mugen Racing Team
also someone told me not to turn the bass inside all the way up but instead adjust it with amp.... cause it might affect the RCA wires.... but right now i have amp on 50% and i adjust from inside... sometimes 4-max clicks for bass depending on song...
Jul 16, 2017 07:33 AM
Timmy18
Oct 17, 2015 03:58 PM
Skirmich
Oct 1, 2015 12:59 PM
Sep 25, 2015 06:05 PM
