TL: Hid help do i to replace a ballast
hey i have a aftermarket 10k hid kit in my car and the lights died. i was wondering can i buy some ebay 6k hid lights and put them on without changing the ballast or w.e? thanks
takin care of Business in
Received 4,732 Likes
holy 10000K batman....
well did both the bulbs die ?
1> check the fuse (i bet that popped) and also check all connections
2> disconnect the ballast and connect some halogens there (assuming you have a 2G or the bulbs are in the fogs)...if the halogens light up means you getting power until there
3> switch the HID bulbs to see if they light up....if they do then something is wrong with ur bulbs
4> if they dont light up, ur ballast are the problems
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
yes....just make sure its the same "type" of bulb....
example: replace a 9006 with a 9006, H8 with an H8, and so on....
No problem
How are you sure its the ballast? Check the bulb for dark discoloration
benny_jdm
01-31-2016 06:15 AM
