hey brian
Old Oct 11, 2001 | 04:35 AM
Akim711's Avatar
dynamic Duo!
hey brian
about the audiolink... i ordered that before, about a year ago, and found out that the harness they thought would work didn't... so i sent it back.
i saw in your sig that you had a custom harness adapter... how did you get that to work? If its easy, or if they make one now, i think i'll get it.
thanks in advance
Old Oct 11, 2001 | 04:44 AM
Akim711's Avatar
dynamic Duo!
Also, you the audiolink has an adjustable pre-out voltage (from what u said, correct me if i'm wrong)...
what is a good setting for that? i'm assuming that anything 4V or above is really good... is it possible to put the setting that high? thanks again.
Old Oct 11, 2001 | 07:16 AM
bc0203's Avatar
Tech Guy / Likes to Drive
According to their specs, you can adjust the output voltage to "at least 2.5V RMS," which was plenty for my application. Unfortunately, you'd have to use a separate device to boost the preamp voltage higher than that.
We did the install today, and the steering wheel controls work fine, and the system really ROCKS now that we've set the crossover points and EQ on the amps!
[ 10-12-2001: Message edited by: Brian Campbell ]
MrHeeltoe
20
Feb 23, 2023 01:54 PM
vpasla1
Sep 17, 2016 07:24 PM
Avenger411
Oct 11, 2015 03:53 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
