help w/ TSX stereo ideas
so while i wait for my TSX to get here, im working on the plans for making the audio better. Im still trying to think of a workaround for the bass boost @ 50hz, which ill tackle once my helms gets here so i can see the schematic...but for now ill do the more simple things. Ive got hookups on Polk stuff, so im going to put in the ex or db components upfront and in the rear door/deck. Thinking about a 12" MOMO sub...Im still trying to think of how ill divide my power. Ive got an 600w 6channel amp w/ xover at the moment that ill probably use. How would you divde the power? I was thinking fronts and sub off the amp and then the rears off the factory amp, but thats just an uneducated guess. Also, if you've got better speaker suggetions, then by all means...ive got a deal on these so i was going to do it unless they just plain suck
To avoid the bass boost, tap into the line inputs before the amplifier as it seems all the equalization and crossover duties are done there... this is an assumption, but it makes sense since there are only four (front/rear/left/right) inputs, but *eight* outputs with different bandwidths and eq curves entirely. So, the signal coming into the amp must be pure...
I do suggest a line driver, though I need to verify the stock voltage.
snorf
11-04-2019 06:44 AM
ivegotthenav
09-11-2015 07:51 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
Gianni Formica
09-07-2015 08:28 PM
