Help with stock sub/amp
Old Aug 16, 2004 | 07:13 PM
has anyone wired an amp to the stock sub?
how big of an amp can you use for a stock sub?
Old Aug 16, 2004 | 08:03 PM
11psiGSR's Avatar
Honda Lover
Dont even consider it. The stock sub is worthless.
Old Aug 16, 2004 | 09:09 PM
SilverIce2000's Avatar
i tried doing it... and all the wiring is done... i just cant find an effin ground in the trunk so i cant turn on my amp... what i plan on doing is try to max out the rear sub until it blows out and then replace it with an 8" free air sub... just dont have the time to find a ground
Old Aug 17, 2004 | 08:04 AM
11psiGSR's Avatar
Honda Lover
Ummm.... Almost everything metal in your car is a ground homie. Just use a wire brush to remove any paint and primer and don't forget to use a start washer. If you really want to find a clean ground, use a multimeter.
BTW- I stand behind what I said above... DON'T use an aftermarket amp with the stock sub. Ask anyone with experience in car audio.
Old Aug 17, 2004 | 01:15 PM
how much power can the stock sub handle? what kind of amp do i need?
Old Aug 17, 2004 | 01:17 PM
would u suggest replacing the stock sub with another 8"? could i put another 8" sub in that area?
is the stock amp wired to the speakers as well?
Old Aug 17, 2004 | 02:15 PM
Hurleysurf24's Avatar
listen the stock sub is not intended to pump out massive amounts of bass... its a freakin bose system it does what its advertise to do like in the commercials, provide crisp clean sound and vocals.
ON THE OTHER HAND ... I want to know how i can make the stock system louder .. i dont want more bass or anything .. i just feel like the audio system should be able to go 10 bars higher on the volume, feels like its holding back
Old Aug 17, 2004 | 03:03 PM
will there be a noticable difference if i put in an aftermarket headunit (without the stock sub) in sound? i don't wanna lose the sub, thats y i wanna wire an amp to it.
Old Aug 17, 2004 | 03:08 PM
If you really want to throw a nice sub in the stock sub spot, I recommend a JL 8" w7 with a 500/1 amp... The stock sub/amp SUCKS man! Don't even think about keeping it.
Old Aug 17, 2004 | 03:24 PM
Da_iLLeZt_TL973's Avatar
Future JDM Whore
so he can keep the other speakers and it would sound good he just has to get rid of the sub and amp is what you are saying??
Old Aug 17, 2004 | 03:30 PM
so will the stock speakers be fine?
Old Aug 17, 2004 | 06:33 PM
fsttyms1's Avatar
why not???? i did it and the stock sub sounds alot better. louder and more bass. of course it doesnt compare to a aftermarket sub and enclouser, but for those of us who need our full trunk its a good alternative
Old Aug 22, 2004 | 12:01 PM
DigiAcura's Avatar
I am installing a aftermaket 1 din MP3 player/recorder (www.estone-tech.com) evaluation unit to my 2000 TL. It has 4x45W amp out put and 4 x pre-amp output. I am using a Metra 70-1721 16-pin harness adapter kit. There is a 12-pin connector on the HU. Anyone know what is this connector for and its wiring spec? How you connect the stock sub?
hashbrown
Feb 18, 2022 11:20 AM
Jul 16, 2017 07:33 AM
vpasla1
Sep 17, 2016 07:24 PM
DerrickW
Nov 15, 2015 05:52 PM
rangomango
California
Sep 24, 2015 05:47 PM
