Help! Radio code doesn't work
Old Jul 22, 2003 | 09:16 AM
mattjpr's Avatar
Hi, all. '99 TL here. Just had some body work done and the battery was disconnected. Now, my radio code doesn't work. I checked with Acura to make sure it's the correct code for the radio and it is.
As you know, you get 10 tries to make it work. If it doesn't, you get 10 more tries after an hour. I've tried about 25 times now. I've also tried disconnecting the fuse and unplugging the battery.
Nothing works. Help?
Thanks!
Old Jul 22, 2003 | 12:47 PM
FTM-1's Avatar
Post
Not sure what the problem might be other than wrong code.
I just had the original OEM battery in my 2000TL replaced last week. The radio ask for the code after the new battery was installed. I entered the code on my radio/navi card & it took the first time. The Nav must have a backup becase it did not need the code to be entered.
mada51589
Jan 9, 2025 04:40 PM
AndrewS
19
Mar 14, 2024 06:59 PM
Ol'Dave
Sep 5, 2020 02:56 PM
acurajj
Sep 19, 2015 03:47 PM
Luis J. Rodriguez
Sep 12, 2015 10:00 PM
