HELP PLEASE
Old Jul 2, 2001 | 12:21 PM
NOLACLS's Avatar
HELP PLEASE
Well I tried to hook up my amp and was un-successful. The amp will not come on. I have the power wire run, but what color is the remote turn on for the stock amp so I can tap into it. Also can I use the ground from the stock amp or should I use a bigger one. Please help!
mark
Old Jul 2, 2001 | 02:05 PM
SilverKnight's Avatar
Retired. Not available.
Originally posted by NOLACLS:
<STRONG>Well I tried to hook up my amp and was un-successful. The amp will not come on. I have the power wire run, but what color is the remote turn on for the stock amp so I can tap into it. Also can I use the ground from the stock amp or should I use a bigger one. Please help!
mark
</STRONG>
check out this link. Hope it helps.
http://www.acura-cl.com/cgi-bin/ulti...c&f=1&t=006254
Old Jul 2, 2001 | 02:06 PM
StreetEffectz's Avatar
Definitely don't use that tiny grond on the stock amp...you can go to ground UNDER the amp where it is bolted in if you like.
As far as the remote turn on wire, I keep forgetting the color, I THINK it's yellow with a white or blue stripe, but I'm not 100% sure...even with that, you MAY need to add a relay because the stock amp only needs 9.76 (in that area) volts to turn on and your aftermarket amp may need at least 11.5 to turn on and stay on, and will run most efficiently around 13 - 13.8 (when the car is running)
[ 07-02-2001: Message edited by: StreetEffectz ]
Old Jul 2, 2001 | 02:34 PM
NOLACLS's Avatar
Thanks yall for the help. Silverknight, so the remote wire is the yel\wht i think its called the radio switch. Is that the one you used?
Old Jul 2, 2001 | 03:04 PM
icy CL's Avatar
that's the one...yellow with white stripe is the remote turn on.
Old Jul 2, 2001 | 03:09 PM
NOLACLS's Avatar
thanks i will try to do it again!!!!!!!
Old Jul 2, 2001 | 03:35 PM
<STRONG>Thanks yall for the help. Silverknight, so the remote wire is the yel\wht i think its called the radio switch. Is that the one you used?</STRONG>
that what I used. but for my curent setup, that wire is ignition now cuz I need an ignition wire in the trunk area.
