help with mounting amps?
Old Sep 15, 2005 | 10:27 AM
tonka_146's Avatar
Registered Driver
so where have you guys mounted your amps... is it safe to put them on the back seat ???
Old Sep 15, 2005 | 11:02 AM
CJams's Avatar
Guinea Pig
There have been a few different places for amps. The back of the seats will work if the amps fit there. Some people mount them on the sides in those cubbies. Thats where my speakers are. Here is my temporary amp rack. I can still drop the back seats and fit longer things in the car. http://i5.photobucket.com/albums/y15...i-IMG_2496.jpg
Old Sep 15, 2005 | 12:33 PM
glott's Avatar
thats a nice trunk setup, wish i had it
Old Sep 15, 2005 | 01:26 PM
Tsx536's Avatar
Rep'n Taxbrain.com
that setup is Phat!
Old Sep 15, 2005 | 01:34 PM
CJams's Avatar
Guinea Pig
Thx!
Whatever you do don't mount the amps upside down underneath the back dash! Those heat sinks are on the top of the amp for a reason
Old Sep 15, 2005 | 10:02 PM
gmfreed's Avatar
if you click on the link in my signature you can see where i mounted my amps.
Old Sep 16, 2005 | 12:59 AM
Spoon's Avatar
Those the component crossovers next to the EQ? Pretty damn big... You don't have any current draw issues with the amps, eq, lighting, who know what else? Just curious.
Old Sep 16, 2005 | 09:12 AM
gmfreed's Avatar
Nope no current draws at all. The neon is only on when the trunk is open. As far as when the bass hits, my interior lights dont even dim. I guess I got pretty lucky with this car, but who knows I never ran this system off the stock battery. When I installed the system I also upgraded my battery to a Optima red top so I dont have that tiny power wheels battery anymore.
Old Sep 16, 2005 | 09:47 AM
dizzy1's Avatar
GMFREED- are you running directly from the factory deck to the EQS or are you using a line driver or dash eq? If you are, what brand of line driver/eq are you using and do you get any extra noise like alot of people on this forum talk about.
Old Sep 16, 2005 | 10:14 AM
Spoon's Avatar
Did you also replace the battery and alternator wiring?
Old Sep 16, 2005 | 03:52 PM
gmfreed's Avatar
I am running straight from the factory deck outputs into the EQS, then from the EQS into the amps. The EQS created a very small amout of noise that i could easily tune out by adjusting the volume of the amps down a little.
Old Sep 16, 2005 | 03:53 PM
gmfreed's Avatar
NOPE, just the battery
Old Sep 19, 2005 | 11:03 AM
cmd's Avatar
cmd
tonka_146, I mounted mine on the back seat with no problems, but hate that cargo could bang up the clean amp.
Originally Posted by CJams
Thx!
I posted my big 4 channel Sony (11x 13ish) up for sale to get a small 2 channel and do just that (like a Kicker which should fit with the end bling removed). Now you have me rethinking that. My Sony's heat sinks are on the sides, still I would think the engineers would design the heat path to go UP and now down. Now mounted to the rear deck (metal to metal) would mean some heat would be transfered by contact, but the heat path would still be reversed. Has anyone tried this? Build an amp shelf perhaps?
Old Sep 19, 2005 | 11:21 AM
CJams's Avatar
Guinea Pig
I have seen a tsx amp shelf under the back deck. Acuradog has/had and amp mounted under the back deck right side up. I would suggest putting it on a set of drawer/hinges so you can kinda unlock and pull it out. The amp racks I have seen require it to be unscrewed to move the amps in order to tune or adjust it.
Mounting an amp on its side is still way better than upside down. If you mount it upside down the heat radiates through the pc board to the bottom instead of to the heat sinks. Could create problems.
Old Sep 20, 2005 | 07:49 PM
gmfreed's Avatar
If you use an amp, like JL Audio slash series, you can mount them in any direction at any angle. Because of their placement of the heat sinks, no matter what direction the amp is, it will still pull heat away from the amp.
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
Froid
Sep 27, 2015 06:16 PM
