HELP!! Grounding my head unit
Old Jun 12, 2004 | 01:15 PM
acuratl_2nr's Avatar
hey,.. ive just bought a new head unit for my 98 civic. I was just wondering if its better to ground it via the wiring harness or to blot it to the dash frame?? there is a spot for a ground on my wiring harness,.. shoud i hook it up there?
any help is appreciated! thanks
acuratl_2nr
2001 Acura TL-P
1998 Civic
Old Jun 14, 2004 | 11:59 PM
Fauman's Avatar
use the harness
Just use the harness, makes no difference. Only time that comes into effect is when your installing multiple amps for high SPL competitions and every amp and volt counts.
Old Jun 15, 2004 | 07:33 AM
AcuraX2's Avatar
Agreed. Unless you run into any noise issues, the factory ground wire should be fine.
Old Jun 15, 2004 | 12:35 PM
keeena's Avatar
Its fine to use the factory ground in most cases. There is a *chance* that you will get noise with your aftermarket HU that you didn't get with the factory HU. Usually you will be OK though.
I personally don't bother wasting my time hooking up the factory ground to find out...I always wire my own the first time around.
Jul 16, 2017 07:33 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
Eggs999bacon
Sep 24, 2015 10:08 AM
