Help With DVD Player Install
Old Jun 21, 2005 | 12:33 AM
veen120's Avatar
distinctiv_tuning
Hey wasup guys...i bout me this DVD player and i was wondering...were do i hook up the Memory Wire?....do i hook it up to a constant?,,,or ACC?....
If i were to tap into the Stock HU...would i connect the memory wire to A10 and the power to A2?
Old Jun 21, 2005 | 12:36 AM
pimpravi's Avatar
I pimp an Audi A4.
im sure someone knows just give it a day or two
Old Jun 21, 2005 | 08:59 AM
elduderino's Avatar
VP Electricity
Memory means Constant, so, yes.
Hope the fuse likes it though.
Old Jun 21, 2005 | 10:03 AM
veen120's Avatar
distinctiv_tuning
can u suggest where else i can tap these wires into?
Old Jun 21, 2005 | 10:10 AM
elduderino's Avatar
VP Electricity
Constant should be fine - usually no draw there.
For switched, first, check the current draw of the DVD player. If it has a 3A fuse I would go ahead and catch the HU switched power. If it's a 5A I would consider it. If it's a 10A I would not consider it, and I would either catch it at the steering column from the key, or I would make a switched relay and run power from the battery (which I am not expecting you to do).
Do you have a voltmeter? Having the diagram is good, but having a voltmeter is better.
Old Jun 21, 2005 | 11:07 AM
veen120's Avatar
distinctiv_tuning
naaa i dont have a voltmeter
here are the specs
Supply Voltage: 12V DC (11V-15V), Negative ground
Current Consumption: Less than 2A
both of the wires have a built in fuse...i dunno wha kinda fuse tho
Old Jun 21, 2005 | 11:22 AM
elduderino's Avatar
VP Electricity
OK, what's the fuse size on each wire? If each wire has a 3A fuse then I'd do what you said before (with the caveat that I don't recommend ANYONE EVER connect wires without testing them with a voltmeter first...)
BoricuaTL
Apr 8, 2016 01:08 PM
bymotion
Nov 18, 2015 11:28 AM
Sep 17, 2015 09:01 PM
TxRzrBk
Sep 17, 2015 01:07 PM
mgbe11
1/2G MDX (2001-2013)
Sep 15, 2015 07:53 PM
