CL: Help! Converting head-unit ipod adapter to AUX output for Blackberry
Old Oct 30, 2009 | 05:15 PM
nazztradamous86's Avatar
4th Gear
I have a Kenwood touch screen head unit with an ipod adapter already connected. I was wondering if there is a way to convert/connect the ipod adapter to another adapter so I can have a AUX output and I could connect it to my blackberry and listen to Pandora. Please, if this is possible then help me out. Thanks.
Old Oct 30, 2009 | 07:26 PM
Jonesi's Avatar
It would help if you gave us a model number rather than "Kenwood touch screen head unit"
Old Oct 31, 2009 | 01:30 AM
Steven Kephart's Avatar
It would also help to know the model number of the Ipod adapter you are using. It looks like the adapters on the current models use a USB input for the Ipod. You may be able to use this cable: http://www.kenwoodusa.com/Car_Entert...ories/CA-C1AUX Do you have the round port that cable plugs into empty on the back of your stereo?
Old Oct 31, 2009 | 05:30 PM
4th Gear
Kenwood - DDX 6019
http://www.kenwoodusa.com/Car_Entert...inment/DDX6019
iPod Adapter: KCA-iP500
Old Oct 31, 2009 | 08:54 PM
There isn't a way through the Ipod adapter. However your head unit does have an AV input. Why not use that? You will probably need an RCA to head phone adapter.
Old Nov 1, 2009 | 02:52 AM
4th Gear
I just wanted to avoid taking out the head unit to add another cable. Can you send me links for the necessary items ill need. Like the AV input, RCA and head phone adapter? Thanks a lot Steven, your very helpful.
Old Nov 1, 2009 | 08:58 AM
Actually the AV input is built in, but will be on the back of the unit. I'm only assuming it is an RCA type of input as that is the most common and we don't deal with Kenwood at work. If it is, then you will need a cable like this assuming your Blackberry has a standard headphone output: http://www.stingerelectronics.com/pr...34&ParentID=20
Old Nov 1, 2009 | 01:11 PM
4th Gear
So ill basically know once I pull out my head unit. Is this Stinger cable good or there is better cables I can go with?
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
Dman00tl
2G TL Photograph Gallery
Sep 25, 2015 10:34 AM
