Headphone jack installation ?s...
This might be very simple or a stupid question but hopefully someone can help...
Attached is a picture of the installation instructions I recieved with the unit. I will have a picture of the unit it self soon up here too I hope.
I want to install these jacks in the rear seat area of my car so that people can plug headphones in and listen to the music or sound of a dvd playing or video game system. I would want to extend the headphone plug-in from the Pioneer VS-33 Video Selector unit in my glovebox to this plug-in in the rear so no headphone wires are need to run all the way to the glovebox.
My question is what exactly I need to attach each of these wires to, to make this all work?
Please help with anything... I will attach other pictures asap.
Thanks,
ERIC
Thanks,
ERIC
Its really hard to see in the pics, but it looks like the Pioneer unit has RCA type plugs. In that case, all you need to do is to get two RCA wires (one for left channel, one for right) and run it back to the backseat where you want to put the headphone jacks.
Connect the INNER left channel RCA wire to the blue wire on your headphone panel, and the inner right channel to the orange wire on your panel. (On RCA wires, the white wire/plug is the left channel; the red wire/plug is the right channel).
Then connect BOTH the outer RCA grounding wires to the white wire on your headphone panel. If you want, connect the pink wire to +12V from the car; this will give you backlight on your panel.
Then you're done. You should be able to get pretty much everything you need from RadioShack, Best Buy, Good Guys, or similar.
cycdaniel
12-17-2019 10:58 AM
