CL: Having some minor electrical issues... Please Help Me!!!
Old Sep 19, 2012 | 06:46 PM
jgoodjr823's Avatar
9th Gear
So I installed two Alpine S series 10 inch subwoofers along with a 1000watt Boss amp to my 2001 cl-s.
Literally an hour after finishing the project, I was cruising around with a friend listening to the new bass and out of no where my dash lights, clock, power locks, and my running lights (head&tail) went out... I checked the ground wire in my trunk from the amp and it seems well grounded. My fuses are all good as well as my bulbs. So I'm guessing its a multiplex problem? I'm not sure...
This wasn't my first time hooking up a car with some subwoofers, but my first time with an Acura. I'm not sure where I went wrong. Does anyone have some helpful advice for me?
Old Sep 23, 2012 | 02:53 PM
n8yates's Avatar
04 tl 19
did you check the fuses with a test light or probe, or did you just look at them because sometimes they look fine but can have a break that is impossible to see with the bare
Old Sep 23, 2012 | 02:54 PM
n8yates's Avatar
04 tl 19
also where did you get the remote turn on for the amp
is it the factory radio or an aftermarket
Old Sep 26, 2012 | 09:45 PM
on1wheel01's Avatar
Not your first time hooking a car p with sub woofers. I cannot express how many times I have fixed installs done by people who have "installed systems before". Have it done by a pro and it will be fixed.
Old Sep 27, 2012 | 07:34 AM
KaMLuNg's Avatar
if factory radio, how did you tap the signals for the amp? did u use a LOC? where did u tap into?
InFaMouSLink
Oct 30, 2015 09:43 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Froid
Sep 27, 2015 06:16 PM
ceb
ILX
Sep 27, 2015 10:56 AM
