hardwire a power inverter?
Old Jun 14, 2004 | 12:36 PM
NYZGREATST's Avatar
Sig Rho's Finest
hey guys. i want to add a ps2 to my car but i have no idea how i would connect the inverter directly to my car, i dont want to plug it into the cigarette lighter every time iwanna use the ps2. any ideas?! thanks in advance
Old Jun 14, 2004 | 12:50 PM
SidS1045's Avatar
dumber than a box of hair
I'd put a fuse block under the hood near the battery, and wire it directly to the + terminal of the battery. Size the fuse 50% more than the maximum current draw of the inverter, to allow for the inrush when you turn it on.
Old Jun 14, 2004 | 01:14 PM
Bxscig's Avatar
Like he said, run a cable from the battery to a fuse to the relay (with or without depending) to the invertor. There are a few ways you may want to set this up depending on what u want. Watever setup u use just make sure that dont drain ur battery.
Old Jun 17, 2004 | 01:54 PM
LegoGT's Avatar
I wired a power inverter to the center console cigaretter lighter adapeter. I took apart the console and spliced it into the connector so that I can still use the cigarette lighter for my cell phone. After that, I mounted the inverter under the passenger seat so that you can't see that it's connected unless you plug something into it.
Old Jun 17, 2004 | 02:56 PM
Bxscig's Avatar
What gauge wire do you plan to use? How big of an inverter is it?
Old Jun 18, 2004 | 08:49 AM
DuckBlue's Avatar
i did what he did.. but put it under the driver's side.. ps2 is under passenger side
wires come out from under the sides of the center console so its hard to see the inverter
Acura604
20
Aug 5, 2017 12:55 AM
spudweb
May 22, 2016 02:39 PM
knight rider
Mar 4, 2016 08:59 AM
mars
Sep 28, 2015 11:03 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
