ground issue?????
ground issue?????
alright i have what i think is a grounding problem......when i'm just sitting there and the car is not moving i getting some noise only out of the sub....its like feedback if i pause the cd or turn the volume down completely i get like a hum of bass like if the music was still on....but when i hit the gas the sound stops.....i'm not sure what it is.....
Former Sponsor
Originally Posted by dreem1er
but wouldn't the noise be constant if it was an input problem.....the noise completely stops when i accelerate even a little.....just touching the gas enough for the rpm needle to move slightly and the noise stops.....
An amplifier does not make an audible reaction because of power loss. If you are physically hearing an audible reaction, the cause is in the audio path. Either before or after the amp. From your description it sounds like the amplifier is receiving the noise. It could be as simple as something touching the RCA outputs on the back of the deck.
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
