got a question
Old Mar 5, 2002 | 04:03 PM
noleaf74's Avatar
got a question
alright i'm going to upgrade my system soon(anybody maybe interested in 2 12" RF He s and a punch 500.2) anyway I'm prob gonna go w/ two 12 eclipse 87 series subs firing them foward through the ski hole with a flush encloser in the trunk with some plexi so u can see the magnets out the back. I want to vent the factory sub location to so i get some bump. I'm think a RF power 800.2 amp on those bad boys, and i'll prob have a 200.4 on my doors. My question is first would i need another alternator & battery or could i get away w/ caps, and if my car is on a lease what kind of trouble am i gonna run into w/ acura if i add an alternator. thanx guys . Austin ur imput would be greatly appreciated
Old Mar 6, 2002 | 04:38 AM
Austin519's Avatar
noleaf74:
Mmmm you don't want to fire through the ski hole. It's a nuisance to have to have down, it rattles, and it sounds awful (bad imaging). I don't understand about venting the stock sub hole also...I mean...I can see you making a standard ported box, and porting it through the rear deck and firing the subs through the ski hole. I've seen it done but it's difficult. But if you're going to vent through the stock sub hole you may as well do what I'm going to do, which is to just get/make a bandpass box and fire a 9" port up through the stock hole in the rear deck...it will give you much better imaging and dispersion, with no worry of cancellation from having different phases coming from the ski hole, and then an out of phase wave coming from the stock sub hole and reflecting off of the rear windshield.
Second, quick comment about the new style RF amps...if you can get the old body design, a picture of which I have attached...aka the ones I am running...that would be better. The new style doesn't compare to the old design.
And with an 800.2 and a 200.4 (you realize that a 200.4 is only 25W per channel at 4 ohms, so make sure to get 2 ohm speakers)...you're only drawing 60 and 10 amps respectively...you should be perfectly fine with the alternator. I would definitely suggest a capacitor though, otherwise that 800W amp will rape your electrical system. My preference, Lightning Audio Digital Storm 1 Farad Caps (w/ LED Indicator)...$85.
Austin519
Old Mar 6, 2002 | 07:43 PM
noleaf74's Avatar
thanx alot man, can i ask u what is ur opinion on the eclipse 87 series good choice bad choice. how are they for sound quality, and do u know anythin about when jl is supposed to relaese the W6v2. thanx again
Old Mar 6, 2002 | 08:29 PM
Austin519's Avatar
noleaf74:
I like Eclipses actually...and I forget what the date on the w6v2's are...I'll have to ask Manville.
Austin519
Old Mar 6, 2002 | 09:13 PM
noleaf74's Avatar
just one more quetion for you austin, why do u specifically reccomend the older RF amps over the new ones what is the big differance, thanx again u have been a ton of help.
Old Mar 6, 2002 | 09:16 PM
Austin519's Avatar
noleaf74:
Although I can't verify this now...but I have been meaning to ask...the new models use a different mosfet setup...and was designed to be more efficient...but IMHO the sound quality is worse. Plus they're uglier. I'd maybe try to get the new RF style amps if possible.
Austin519
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
