Good speakers
Old Dec 4, 2003 | 03:32 PM
Patrick_149's Avatar
Polk db650
Hey, I have been thinking about putting the polk db650 in my tl for front speakers. Has anyone used these before or what do you think about them?
Old Dec 4, 2003 | 10:43 PM
i got some infinity's. 6 x 9s and 6.5s. they sounds decent w/o an amp or aftermarket wiring and using stock deck. btw i have a '96 2.5
Old Dec 4, 2003 | 10:45 PM
Well i don't think we could compare the 96 deck to the 2001 i have now. I think it is totally different....
Old Dec 6, 2003 | 12:34 AM
VTEC11's Avatar
i too have been thinking of getting some db650's. But there pretty new so i don't think anyone really has used them...
Old Dec 6, 2003 | 10:36 AM
Yea they are very new, so your right, they may not have been used before, although i am going over to the store to checkt them out today, and possibly installing them in car today as well. If so i'll tell you how it goes.
Old Dec 7, 2003 | 01:50 PM
Well i got the new polk db650, at a decent price as well, 150CDN tax in. Installed them as well, everything went amazing, they fit perfectly in the original basket, fit into the screw holes and everything, no mods. The only thing is that they are a bit bright...not that bad, but they could sound better if possibly i put on the southbound mod maybe, to reduce the high frequencies. So i might do that a little later on. For now they are a great! improvement compared to the ****ty blose that were in there. All i want to do now is disconnect the old sub, and a nice clean sounding one in.
Pat
Old Dec 11, 2003 | 10:43 PM
bullybreed's Avatar
well i manage an electronics store here in nashville and we carry the new db polks and i like them alot ..some of the best speakers ive heard for that price..im getting the 61/2 for the rear door and the 61/2 comp. set upfront..i would replace the headunit if possible or run a HLC to hook an aftermarket amp up to them..but i would reccomend them myself..u will like them...99 TL
Old Dec 12, 2003 | 11:03 AM
Scott P's Avatar
Mobile Elec. Guru
bullybread i am an installer in memphis and I am doing the same thing. Patrick does make a good point though, unless you run them through an amp they do come off a little bright in the car. I personally am going to run them through a jbl 4channel xover and then through an amp set at full range. I haven't tried that set up with the polks, but having use RF and Cerwin Vega's doing that I think it ought to sound pretty good.
Old Dec 15, 2003 | 01:11 PM
VTEC11's Avatar
patrick,
did you just install the speakers only.. Or did you bypass the EQ first? If not, i think any speaker would sound bright..
Old Dec 15, 2003 | 02:50 PM
kent_99TL's Avatar
Originally posted by vtec11
patrick,
I believe vtec11 was right, it will sound real bright without bypass the eq, even if you bypass the eq without power you speakers with an amp the volume will be down at least 50% compare to your stock setup. Do a search about the DX6 mod that SB created year ago then you should know why.
By the way I have "two pairs 4 speakers" with SB mod polk DX6 for sale under for sale section, please PM me if anyone interested.
AndrewS
19
Mar 14, 2024 06:59 PM
sockr1
Oct 1, 2015 01:31 AM
Pegon95
Sep 15, 2015 01:54 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
NSolace
Sep 3, 2015 08:02 PM
