Getting 13.8VDC Thru the firewall of a 2004?
Old Apr 9, 2004 | 04:14 PM
Kent Hufford's Avatar
7th Gear
I'm trying to snake a 12 gauge powercable thru the firewall of a 2004 TL. In one of the posts here, they say there is a pushout "above the gas pedal". I cannot seem to find the pushout. Is there one in the 2004, and how far above? Or does someone have another path?
Thanks in advance
Old Apr 9, 2004 | 06:14 PM
shawhite's Avatar
in every car that i have ever seen in my life there is a grommet in the firewall that you can run a power wire thru... it would probably be easier to find it in the engine bay... i know that the 99-03 tl's had the push out you are talking about above the gas pedal... i am not sure about the 04's... but i am sure if you look hard enough then you will find it.. another thing what are you running 12ga wire thru the fire wall for.. i hope that you are not planning on powering any decent amp with that little cable.. at least go 8ga...
Old Apr 9, 2004 | 06:51 PM
Troy36's Avatar
yes it is above the gas pedal. Way above and more towards the center of the car. I have a picture of where it is I can send you if you want. I fished 4 ga through there. You have to pop it with a small flathead or use a pair of needlenose to pull it out from the engine bay. Inside there is some sound deadening material covering it so you have to pull that out a little and reach way up there with your hand once you fish the wire through. A flashlight helps a lot.
Old Apr 9, 2004 | 07:06 PM
7th Gear
Yes, a photo might help. khufford@comcast.net
thanks
GWEEDOspeedo
Jan 15, 2016 10:39 PM
Nizmosis
Oct 13, 2015 02:25 PM
TLguy42
Sep 26, 2015 11:27 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
2Quik
Sep 23, 2015 01:03 PM
