gave up trying! help!!!
Old Jan 20, 2003 | 11:54 AM
Sdog2012's Avatar
We dont love these hoes
Me and a couple other kids put in my subs the other day, they convinced me that it was better to just run the rca's and the remote to the back of the deck instead of tapping into the bose amp. We have everything hooked up fine, power is going to the amp.. wiring connections are all fine, yet there is no signal going to the subs at all. any help would be great!
Old Jan 20, 2003 | 12:24 PM
nokio's Avatar
back up and just tap a line from the rear deck speakers if all else fails
do our headunits even have rca's? u sure u didnt plug them into something else?
Old Jan 20, 2003 | 12:36 PM
Sdog2012's Avatar
i have a new deck with rca inputs
Old Jan 20, 2003 | 12:56 PM
brianlin87's Avatar
ASM I.S. Design FTW.
check wiring again, sounds like it should work fine
Old Jan 20, 2003 | 01:32 PM
shawhite_RENAMED's Avatar
ok first off you do have the remote turn on lead hooked up... 2nd does your headunit have a subwoofer control... if so make sure that the sub preamp is turned on on the headunit...
Old Jan 20, 2003 | 02:30 PM
Sdog2012's Avatar
Ive checked the wiring twice now, and i know we have the remote hooked up but im thinking that might be the probelem, mabye it wasnt hooked up right...
Old Jan 20, 2003 | 05:01 PM
do you have a subwoofer option on the headunit... if so make sure it is turned on.... what head unit are you using???
Old Jan 20, 2003 | 09:31 PM
Sdog2012's Avatar
yes it is turned on too, i have the alpine cda 7874
Old Jan 21, 2003 | 08:30 PM
imports4life's Avatar
problems w/stereo
whats up,
u are most likely having problems because u either have to one of two things.either run speaker wires from the front and rear speakers to them stock bose amp or run speaker wires from the bose amp to your aftermarket amp.see,when u have the bose stereo,all the speakers are tapped into the bose amp.that is the only signal they recieve so u have to bypass that.let me know how u make out.seeya--imports4life2003@yahoo.com
TL-Rocket
Apr 29, 2023 02:33 AM
rcs86
Aug 2, 2016 06:52 PM
adrian_s2k
1G RDX (2007-2012)
23
Jan 12, 2016 04:25 PM
AJRozsa
Oct 5, 2015 07:50 PM
