free air sub
Old Aug 11, 2002 | 10:52 AM
rmarin2's Avatar
free air sub
Can anyone recommend a good quality free-air sub that can be used to replace the stock sub? I plan on doing some modifications to the torsion bar so that I can mount a 10" sub in the stock location.
Thanks!
-Rich
Old Aug 12, 2002 | 10:33 AM
rmarin2's Avatar
Well I successfully removed the bar runs under the sub location. Now my problem is that the hole is not wide enough to fit a 10". It seems that I need another 1/2" of space. I really don't want widen the hole so I think I'll try to mount the speaker from underneath. If anyone has any suggestions please feel free to let me know!!
Thanks!
-Rich
Old Aug 13, 2002 | 10:19 AM
randomwalk101's Avatar
Why don't you just put a RMB8 Kicker in there? It fits perfectly. I just did it recently. DO a search on and you'll find it.
Old Aug 13, 2002 | 10:45 AM
rmarin2's Avatar
The main reason I haven't done it yet is because the RMB8 is a mid-range bass driver. I'm looking for a true bass driver. I want a nice thump when I play it. I'm not looking for a chassis shaking thump but a really good deep thump. I don't think the RMB8 will give me that!
Old Aug 13, 2002 | 03:03 PM
I wish you were local and I'll let you listen to mine. It sounds really good. Very deep bass (but not as strong as the JL 12w3 in a box I have had)..but hey, it's free air and only 8" comparing to the 12" JL.
Anyhow, I don't think you can find one true sub that is 2" mounting depth that would fit into that stock hole..trust me..I've spend hours and hours searching.
Old Aug 13, 2002 | 03:47 PM
autophile1's Avatar
what about the Illusion Audio ND-8? 2.2 inch mounting depth...
Bryan
Old Aug 13, 2002 | 03:48 PM
autophile1's Avatar
The LM-8 should work too...
Bryan
Bryan
Old Aug 13, 2002 | 04:12 PM
rmarin2's Avatar
I'm no longer restricted by mounting depth. I removed the metal bar that runs across the stock sub location and I can comfortably fit any size sub in there. The torsion bars are not in the way! I am restricted to the diameter of the new sub, unless I make the stock hole bigger to accomodate a 10" or 12".
Old Aug 13, 2002 | 04:13 PM
rmarin2's Avatar
Bryan
Thanks, I will check on the specs for both!
Old Aug 13, 2002 | 05:45 PM
drcookie's Avatar
If mounting depth is not an issue then there are a few (not a lot) IB subs out there that available. Pioneer and Image Dynamics make some free air subs that sound pretty good. I have seem a member in this forum installed the Pioneer IB sub on stock location.
Check out the link here :
http://www.acura-tl.com/forum/showth...oneer+free+air
Cheers !!!
Old Aug 14, 2002 | 07:14 PM
splitz's Avatar
JL
Try a JL 10ib4, it is a free air and its a 10".
Old Aug 21, 2002 | 11:10 PM
SuperDave's Avatar
If you want a deep-playing sub and depth isn't an issue, then look at the JL Audio 10W7. However, I think you will soon realize you will have a depth problem.
David
P.S. Sorry...mainly being a smarta$$. I wanted to get one but it would almost reach the floor of the trunk.
Old Aug 22, 2002 | 08:04 AM
splitz's Avatar
The mounting depth isnt the problem with that sub, its the fact that it is not a free air, and would need a custom box built it you wanted to have it fire into the cabin.
Old Aug 22, 2002 | 09:45 PM
SuperDave's Avatar
Splitz:
You may be right. I am more familiar with the Image Dynamics IDMAX, which is the main competitor to the W7. The IDMAX is capable of being used freeair so I was assuming the W7 could also operate freeair. It actually might be able to. If only IDMAX came in other sizes besides 12".
David
Biggie_B
May 27, 2025 05:51 PM
SidhuSaaB
May 30, 2020 12:40 AM
rcs86
Aug 2, 2016 06:52 PM
spudweb
May 22, 2016 02:39 PM
steve
Sep 30, 2015 09:23 PM
