Finally started on install. Need advice.
Old Jan 9, 2003 | 04:50 PM
bozzchem's Avatar
Well, I finally started today with the 1 hour of daylight that I had.
I ran the speaker wire from the trunk up to the column that holds the seatbelt and sits between the front and rear doors. I can't seem to find a way to get around the factory wiring harness plug mounted on the chassis side to be able to fish the wire through to get to the door side.
I gave up since it was dark and the mosquitos were beginning to enjoy me a little too much.
If you've run speaker wires to the doors, how did you get around the factory wiring harness to get the wires to the door?
I'll be trying again tomorrow.
Thanks.
Old Jan 9, 2003 | 05:49 PM
ChinozTL's Avatar
Are you refering to the back doors or front doors? When I did the back doors I had to unbolt the seatbelt system right at the bottom of the center pillar. Then I ran the wire from the inside of the door panel to the inside of the car. Used some vaseline to help the wire get through.....its a tight fit but will go through. The hardest part is getting through the rubber wire cover running between the door and the body, for that I took one end of the rubber cover off and then pased the wire through and put it back on. The front doors were done in a similar fashion from the inside of the door panels through the door, through the ruber cover, and into the body of the car......then I took a flashlight and looked under the dash to see where the wire came out and pulled it through. Hope this helps, I wsh I had pics but I did it last summer and didnt take any.
Old Jan 9, 2003 | 06:28 PM
Sask32TL's Avatar
Re: Finally started on install. Need advice.
Mosquitos in January????
B*stard...
Old Jan 10, 2003 | 02:02 AM
systek's Avatar
chinoz is right. for the rear doors, you really have to remove the seatbelt and all...it was a major pain in the azz..but it got worse when trying to do the front doors. here's a hint, go to home depot and buy a variety pack of zip ties. this way you will have left overs to use through ur install. use the largest zip tie, which should be thick and stiff. zip tie it to the end of your wire, and use it to snake through the door. once it comes out the other side, PULL....
Old Jan 10, 2003 | 01:05 PM
bozzchem's Avatar
Thanks for the zip tie idea! I was racking my brain trying to think of something that was more flexible than a hanger yet stiff enough to push through whatever hole I can find.
I've got some mamby jamby sized zip ties from some other project I did God knows when. I'll give it a go!
Old Jan 10, 2003 | 10:02 PM
bozzchem's Avatar
Rear doors have been wired. Thanks for all of your tips/tricks. I ran wire up to the front doors but don't have time to run them into the door yet.
Hopefully I'll be able to get the rest of the system in soon.
Old Jan 11, 2003 | 01:11 AM
systek's Avatar
let us know which method made it easiest to run that wire through the door. im sure alot of peeps would appreciate ur input.
as for my amp rack, i have pix of it at my site. here are a few that show it w/and w/out the seat.
when the back seat is put back it looks just like this
but the amps are closer and the amprack is angled to the back seat. that is what i dont pix of though. and since i took that rf 400a4, i cant take pix of it anymore. sorry.
i'll take pix of what it looks like right now, since im still using that rack to temporarily mount my new amp..but that location cant be used anymore, cause the amp is sooooooooooo huge...you'll see what i mean when the pix are up..jeje
rockyboy
Aug 4, 2024 10:35 AM
jspangan
ILX
19
Aug 30, 2016 05:37 PM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
obert
Dec 14, 2015 11:36 PM
