Factory x-over access?
Old Jul 22, 2004 | 05:06 PM
Castles_Saloon's Avatar
It seems as though this forum has a very extensive amount of knowledge. Hopefully, my question requires just a simple answer.
How does one access the crossover? Has anyone done this and modified with any success?
I'm looking to change the signal that the tweeter receives before looking at replacements such as the LPG 25NFA or equivalent Vifa tweeter. Hopefully, new drivers can be avoided for cost reasons.
If this question has been pursued in a prior thread, then I apologize and could someone please forward me to that thread?
Thanks...
Old Jul 22, 2004 | 05:12 PM
Dan Martin's Avatar
Photography Nerd
I believe it is built into the amp behind the CD storage compartment. I don't think you'll have much luck tapping into it.
Old Jul 22, 2004 | 05:25 PM
Is the amp unit detachable from the rest of the CD storage compartment and/or HU?
If not, are there better mechanically fitted tweeters than the LPG and Vifa units available. My mechanical expertise is limited so the better fitting the tweeter the less chance of me messing up some custom work.
BTW Dan_Martin, your icon is f**king hilarious... Is it Rambo photoshopped?
Old Jul 22, 2004 | 06:03 PM
Dan Martin's Avatar
Photography Nerd
Yep, you're new here but I'm sure you'll see plenty more variations of the flaming bag head. This is the one that started it all:
Old Jul 22, 2004 | 06:12 PM
Keep the bag head pics a coming!!
Old Jul 22, 2004 | 11:13 PM
elduderino's Avatar
VP Electricity
Castle, the xover is entirely active within the amp... but the amp is fed by F and R full-range preamp outputs with an 800mV peak-to-peak output level using the Alpine CAN test disc. So it's not hard to use with an upgraded amp, as many here have discussed.
Old Jul 23, 2004 | 02:15 PM
Maybe its a pipedream, but depending on the accessibility of the existing amp, the x-over certainly could be tweaked with whether its an active or a passive network.
I've never actually looked into the belly of this beast to see how difficult it would be to remove just the amp. For other users' endeavors, did you remove the factory amp or did you just bypass it? If you removed it, then could you please forward me to a thread or explain how it was done?
Old Jul 23, 2004 | 02:26 PM
elduderino's Avatar
VP Electricity
Well, if it's active and it's programmed into an IC, then I'd say that the ROI on the effort required to try to modify it is poor.
If it's an LC network on the PCB, someone with enough OCD tendencies could trace it out as long as they weren't taking their meds : ) Lotta work, and you're still stuck with crappy speakers with a short lifespan and an underpowered amp with harsh HF sound.
Are you asking about removing the amp to examine? See the section in FAQ's on installing the SHOND... that tells you how to get to the amp. Then it's four bolts and two plugs... easy.
Usmcgrunt47
Oct 13, 2023 09:35 PM
rcs86
Aug 2, 2016 06:52 PM
steve
Sep 30, 2015 09:23 PM
Birdflunuggetz
ILX
Sep 28, 2015 01:14 PM
lowgrowl
Sep 26, 2015 05:18 PM
