Factory Sub
Old Nov 1, 2004 | 07:11 PM
Niko2000TL's Avatar
...::AOA::...
Factory Sub
Ive been reading all the threads on this subject and cannot get a specific answer to my question..... I am replacing the stock HU with an alpine cda 9835, and i am going to add a separate amp and subs via rca's later. My problem is, i want the stock sub to work when i install the alpine cd player. I am getting confised with all the write-ups on the eq bypass and such. If someone could tell me, what wires to i splice into on the 12 pin harness to make the stock sub work. Where do the wires on the 12 pin harness that i splice into go on the 20 pin harness? If someone can please give me some info on this it would be greatly appreciated...
Thanks,
Niko
Old Nov 2, 2004 | 11:45 AM
oVerBoost's Avatar
HELP!
no worries, your stock sub will still work when you replace your HU
Old Nov 2, 2004 | 01:20 PM
Torkguy's Avatar
if your sound system is like my fathers 03 TL, you can easily make the factory sub work, but it will need a pre-amp signal (and other power and turn-on signal). it is easy to find wich wire you need to tap into with wiring diagrams
Usmcgrunt47
Oct 13, 2023 09:35 PM
rcs86
Aug 2, 2016 06:52 PM
Birdflunuggetz
ILX
Sep 28, 2015 01:14 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
RadiantCycles
ZDX
Sep 26, 2015 09:18 PM
