TL: Error-1 from CD changer after battery reconnection
Hi, I disconnected the battery to replace the HID bulb. When I reconnect the battery and input the radio code the CD changer showed "CHECK" and then "error1". Radio works fine. 2003 TL. 6 CDs inside. Every time when I turn on the power (radio is still off) there is sound of motor from the CD changer, like it's changing CD inside. The same sound appeared when I turn off the power. I got the same check and error-1 code when I turn on the radio. No response from load, eject or selection button. I have tried banging and disconnecting and reconnecting battery. Did not work. Anybody can give me some suggestions? Don't want to bring it to dealer at this moment. Thanks!
See if something got jammed....
Try this.... during its changing sound... Bang the passenger side of the radio with your palm. See if it can shock it into catching. Trays could be a little misaligned....
Also I have a step by step way of removing the tray and fixing the changer. Just search
MetalGearTypeS
Aug 29, 2016 08:28 PM
