EQ on 2000 TL
Old Mar 18, 2004 | 04:05 PM
8th Gear
EQ on 2000 TL
I am fairly new to this forum and I keep seeing posts regarding the need to bypass the EQ in order to install new speakers. What EQ is this? My Bose unit has seperate bass and treble buttons but no EQ. Can I r/r my factory speakers with no problem if I don't have this EQ?
Thanks in advance....
Old Mar 18, 2004 | 06:53 PM
shawhite's Avatar
the eq is a hideaway unit... it is located right above your radio or right behind the ac controls in your dash.. your car has an eq... you can replace your door speakers without bypassing the eq.. i believe the only time you need to bypass the eq is when you are planning on using an after market amp to power the new door speakers..
Old Mar 19, 2004 | 11:21 AM
fsttyms1's Avatar
i would bypass the eq if you get different speakers. they wont sound as good ig you dont
snorf
Nov 4, 2019 06:44 AM
ceb
ILX
Sep 27, 2015 10:56 AM
huskynut
Sep 24, 2015 08:10 AM
max4swag
Sep 14, 2015 07:55 AM
Mike Bertram
Sep 10, 2015 09:27 AM
