EQ on 2000 TL
Old 03-18-2004, 04:05 PM
8th Gear
EQ on 2000 TL
I am fairly new to this forum and I keep seeing posts regarding the need to bypass the EQ in order to install new speakers. What EQ is this? My Bose unit has seperate bass and treble buttons but no EQ. Can I r/r my factory speakers with no problem if I don't have this EQ?
Thanks in advance....
Old 03-18-2004, 06:53 PM
shawhite's Avatar
the eq is a hideaway unit... it is located right above your radio or right behind the ac controls in your dash.. your car has an eq... you can replace your door speakers without bypassing the eq.. i believe the only time you need to bypass the eq is when you are planning on using an after market amp to power the new door speakers..
Old 03-19-2004, 11:21 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
i would bypass the eq if you get different speakers. they wont sound as good ig you dont
snorf
11-04-2019 06:44 AM
ceb
ILX
09-27-2015 10:56 AM
huskynut
09-24-2015 08:10 AM
max4swag
09-14-2015 07:55 AM
Mike Bertram
09-10-2015 09:27 AM
Quick Reply: EQ on 2000 TL
