enough power for a sub?
Old Mar 21, 2007 | 07:23 PM
Meinbeast's Avatar
I have a PG 200.4 (200w rms x4 @4ohms) to power a pair of Polk SR6500 components
AND
a 10 or 12" sub
Ill have the PG amp bridged to give a single sub 400 watts rms..is that enough power?
what do you guys think?
Old Mar 22, 2007 | 11:04 PM
ms_cls's Avatar
Only CL in town!
what can your subs handle? do you want it to hit real hard? or just engugh to know that you have something back there? if you want some good quality sound with out alot rattling then this should be good. if you want it loud then go bigger and dynomatt your car.
Old Mar 23, 2007 | 12:44 AM
uncald4's Avatar
Former Sponsor
Now way. That amp does not have enough power to run that gear. It'll fry lickety-split!
Unless... you boosted the input signal with a line driver. Phoenix Gold is one of the only amps that will accept a high voltage input and be alright. Phoenix makes a PLD-1 line driver. Or a TI.PLD-1 (Titanium). I have one in my TL running to a Phoenix 6 channel. It loves it! Sounds awesome. If you're set on that amp spend a few duckets on a line driver. Don't try to run that gear on that amp alone. You'll be sorry!
Old Mar 23, 2007 | 02:14 PM
mercman's Avatar
Why would boasting the input signal increase the amps ability to run his gear?
Using a line driver can reduce the amplification of noise picked up on the signal interconnect but won’t change the power output of the amp.
There are three surefire ways to fry am amp.
Driving too low of speaker impedance.
Low supply voltage
Inadequate ventilation.
These are all installation problems. To say an amp will fry because it is too small or doesn’t receive enough audio drive is wrong.
To say am amp is too small to drive a particular woofer or speaker to an expected SPL is correct.
I’m not familiar with his amp but doubt the 400w RMS spec, if the amp is too small for his big sub, upping the input level won’t help.
jeff
Old Mar 23, 2007 | 04:11 PM
uncald4's Avatar
Former Sponsor
Low supply voltage
jeff
You're the PROFESSIONAL!
Old Mar 25, 2007 | 05:02 PM
Meinbeast's Avatar
Amp specs
# C--E--A 2006 Compliant
# 200 RMS WATTS X 4 CHANNELS @ 4 Ohms @ 14.4V
# 400x2 watts Bridged RMS Power @ 4 Ohms @ 14.4V
# Top-Mounted Controls
# Bass Boost: 0 - 18 dB
# Frequency Response: 20-20,000 Hz
# Signal to Noise Ratio: > 100 dB
# Dual 24 dB / Octave high and low pass and even by-pass Crossovers
# Continuously Variable from 40 Hz to 400 Hz
# X200.4 Precise Settings
# Twin-T 0 18 dB of pure Bass Boost
# Full Range Auxiliary Outs
# You can bridge 2 channels to one and use the other 2 seperately
# Output optimizer eliminated distortion
# Enhanced Aluminum Heat sink
# Exhaust Vents
# Ultra-Quiet high powered Speedy spinning cooling Fan
# Temperature Monitoring
# Auto Output Optimizer
# Bright 5 mm. L.E.D. Power Indicator
# Requires 4 guage wire kit
many others with this amp on car audio forums have used the set-up options that I am considering...
I wasn't sure about the frying the amp comment as well.
Acura604
20
Aug 5, 2017 12:55 AM
spudweb
May 22, 2016 02:39 PM
knight rider
Mar 4, 2016 08:59 AM
mars
Sep 28, 2015 11:03 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
