eclipse ESN deactivation
i have an older eclipse 5340 in one of my cars and im taking it out to upgrade to a newer headunit. it has ESN activated, and i have the "key CD" but before i take it out, i want to deactive ESN because i'm going to sell it. Does anyone know the key sequence to do this? i lost my manual a long time ago for it.
(please post if you also know how to re-activate it so i can tell the person i'm selling it to)
Thanks for your help.
Not Asian
You might want to try to call Eclipse's 800 number. I don't have my manual with me. I had to call them when my disc wouldn't work and we went step-by-step to reset the ESN.
o-qua tangin wann
"How to cancel the Key CD:
1. turn OFF the power
2. Press and hold button [1], then the [FUNC] button, and hold both for more than one second.
A [SEC] message appears, then it two seconds it will change to [DISC]
The front panel opens; the cd8051 is now ready to accept your Key CD in the CD slot.
3. Insert your Key CD into the slot.
the front panel closes.
A [CANCEL] message appears, the front panel opens, then the key CD is ejected.
The Key CD is cancelled.
*ATTENTION*
- This process cancels the protection for the ESN deck.
- If power to the ESN deck is disconnected, then reconnected, a Key CD will not need to be inserted in order to return the unit to normal operation.
-Inserting a CD other than the Key CD will not cancel the protection. Instead, the display will show [ERR] for two seconds, then the normal CD playback mode will activate."
Eclipse 800 # is 800-233-2216
Hope that helps, it should... I copied it verbatim from my CD8051 Manual.
*ATTENTION*
*ATTENTION*
*ATTENTION*
Eclipse 5301
Cancel a key cd
turn the ignition on and the esn tuner on
Press 1 and then TU and hold both for 0.5 sec.
Deck reads SEC and then DISC
Insert key cd
Deck reads CANCEL and ejects disc.
Cancel a key cd
Insert key cd
jahkesh
04-16-2003 07:01 PM
