easy ? on amp ohms for sub ohms
Old Nov 13, 2003 | 03:20 PM
BRCLS's Avatar
I want a kicker kx 400 mono amp. it is 2 ohms
do I get a sub (l7 8') with 2 ohms or 4 ohms?
or do you recomend I get a amp with 4 ohms?
Old Nov 13, 2003 | 03:25 PM
proaudio22's Avatar
-S namyaC-
The L7s come in 2ohm Dual Voice Coil and 4ohm DVC. To make 2ohms from one sub, you need to get the 4ohm DVC. You wire the terminals in parallel and you'll have 2ohms.
Old Nov 13, 2003 | 03:53 PM
wakeboardfusion's Avatar
Miss th 3.0
depends on how u wire it
Old Nov 13, 2003 | 04:04 PM
RR32CLS's Avatar
"hey...wanna f^&k"
since your amp is 2ohm mono stable. if you will be running (1) speaker, you need to get the dual 4ohm speaker, parallel it down to 2ohm and there you go.
Old Nov 13, 2003 | 04:09 PM
BRCLS's Avatar
So if I want that amp(2 ohm) I need to get the 4ohm speaker.
a 2 ohm amp wont power a 2 ohm speaker?
Old Nov 13, 2003 | 04:10 PM
BRCLS's Avatar
thanks!
tsx_boy
Dec 13, 2019 08:33 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
