Dynamat??
Old Apr 26, 2009 | 11:14 PM
rtea2008's Avatar
What's in your
Dynamat??
Hi, where can you find a good price for some dynamat? I see there's a lot of people on here that are fully covered! looks really nice and I want it too! haha
Old Apr 26, 2009 | 11:35 PM
on1wheel01's Avatar
craigs list for left overs ebay for full kits also search for cheaper alternatives
Old Apr 27, 2009 | 06:09 PM
mattastick's Avatar
http://www.raamaudio.com/cgi-bin/index.cgi?p=pr
Same stuff without the brand name... Makes things a lot cheaper...
Old Apr 27, 2009 | 10:34 PM
nf3d0149ab's Avatar
^ Thanks for the link.
Gonna check it out.
Have you used this product yourself?
Old Apr 27, 2009 | 10:37 PM
mattastick's Avatar
Not yet, but I will be using a bunch of it this summer. I have however heard from multiple users that this is the best stuff for the money. And 2 of those guys have run most of the deadeners out there: dynamat extreme, damplifier pro, etc. and they still standby raamat...
Old Apr 27, 2009 | 10:46 PM
nf3d0149ab's Avatar
Cool.
Yeah I like the price point.
Are you going to use the RAAMmat BXT™ or Ensolite™ MLC?
Or does one work better for a certain scenario?
Old Apr 27, 2009 | 10:59 PM
mattastick's Avatar
The Raamat BXT is actual deadener. The Ensolite foam is just a closed cell foam. I will be using both (whenever I get around to glassing in my trunk). The Raamat will be completely covering all inside trunk faces (I think I can get away with 2 layers throughout the entire trunk for comps) except the area where I will have fiberglass. Between the glass and sheet metal, I will place some Ensolite foam to keep the glass from vibrating against the sheet metal...
Old Apr 27, 2009 | 11:09 PM
nf3d0149ab's Avatar
So where is it appropriate to use the foam exactly?
Old Apr 27, 2009 | 11:57 PM
Rocket_man's Avatar
Summer is Coming
I spent Sunday putting eDead80 in my trunk. I was installing a rear-view camera and took the opportunity to do the trunk. I didn't cover then entire trunk, that seemed like overkill for me. I concentrated on the inside rear quarter-panels and the trunk lid. Once you take out the trim you can reach around the passenger side and get some deadener on the wheel wells. Use the "knuckle" test to see what is still 'ringing' and what needs a little more. I used 20 sq feet in the trunk. I'm guessing if you did the entire truck with 2 layers you are looking at 50-60 sq ft. Probably diminishing returns after awhile but it is your call. Doing the trunk actually made a very noticeable difference. I didn't deaden because I'm putting a subwoofer in there, just wanted to cut down on road noise. This weekend I'll work on the door.
The eDead 80 worked really well and is 80 mils vice 60 mils of the RAAMat. If you join the Ed forum you can find a 20% off code for all eDead products.
Old Apr 28, 2009 | 06:28 PM
monkeybutt's Avatar
How is the odor?
Old Apr 28, 2009 | 07:57 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
I used about 200sq ft of edead v1se2 60 mil.I've gone over the car completely with 2 layers atleast ,making it 120 mil think and most of the trunk now is got 3.Almost a year its been on ,threw all seasons and no pelling no bad smells and pretty easy to install.http://www.cardomain.com/ride/3152723
Old Apr 28, 2009 | 08:55 PM
Rocket_man's Avatar
Summer is Coming
Originally Posted by monkeybutt
How is the odor?
No smell at all.
Old Apr 28, 2009 | 08:57 PM
Rocket_man's Avatar
Summer is Coming
Wow 200 sq feet! That's a ton of eDead... we not quite 2,000 lbs but close FYI.. each 30sq ft roll of eDead 80 weighs 20 pounds.
Old Apr 28, 2009 | 11:43 PM
on1wheel01's Avatar
I've got 4 cans of expanding foam in my trunk helped a ton
Old Apr 28, 2009 | 11:55 PM
nf3d0149ab's Avatar
^ Does the expanding foam weigh the same as the mat material?
Old Apr 29, 2009 | 06:59 AM
on1wheel01's Avatar
I have no clue on that ? but it helped a ton on rattle, my trunk lid is heavy as crap now
Old Apr 29, 2009 | 11:49 AM
nf3d0149ab's Avatar
Might have to upgrade your trunk springs now to gas shocks...I've seen some people do that on the CL.
Old Apr 29, 2009 | 09:33 PM
Yea if you plan on going fast dont do it.Ive added 100-120 pounds I think.
Old Apr 29, 2009 | 09:59 PM
on1wheel01's Avatar
eh it's no biggie if the car is level and no wind lol it will stay up. But I never pop my trunk when ppl ask what I have I tell em a jensen 10 and they just look and say for real lol
Old Apr 29, 2009 | 10:56 PM
mattastick's Avatar
I tell them to turn around... The way I build my box, you can see the motor of the sub through the ski pass... I win
Old Apr 29, 2009 | 11:12 PM
nf3d0149ab's Avatar
That sound deadening weighs sooo much...that's
Old May 3, 2009 | 03:44 PM
timberland73's Avatar
99 TLS6 08 TL
Here's what you see when in my back seat:
AcuraKidd
Apr 23, 2007 06:33 PM
digital_04
Sep 16, 2006 11:32 PM
ASuddenSilence
Jul 17, 2005 06:15 PM
ReflexRacing_com
Oct 24, 2002 12:49 AM
ZeroPSI
Jun 20, 2002 05:22 PM
