Dynamat??
Not yet, but I will be using a bunch of it this summer. I have however heard from multiple users that this is the best stuff for the money. And 2 of those guys have run most of the deadeners out there: dynamat extreme, damplifier pro, etc. and they still standby raamat...
The Raamat BXT is actual deadener. The Ensolite foam is just a closed cell foam. I will be using both (whenever I get around to glassing in my trunk). The Raamat will be completely covering all inside trunk faces (I think I can get away with 2 layers throughout the entire trunk for comps) except the area where I will have fiberglass. Between the glass and sheet metal, I will place some Ensolite foam to keep the glass from vibrating against the sheet metal...
Summer is Coming
I spent Sunday putting eDead80 in my trunk. I was installing a rear-view camera and took the opportunity to do the trunk. I didn't cover then entire trunk, that seemed like overkill for me. I concentrated on the inside rear quarter-panels and the trunk lid. Once you take out the trim you can reach around the passenger side and get some deadener on the wheel wells. Use the "knuckle" test to see what is still 'ringing' and what needs a little more. I used 20 sq feet in the trunk. I'm guessing if you did the entire truck with 2 layers you are looking at 50-60 sq ft. Probably diminishing returns after awhile but it is your call. Doing the trunk actually made a very noticeable difference. I didn't deaden because I'm putting a subwoofer in there, just wanted to cut down on road noise. This weekend I'll work on the door.
The eDead 80 worked really well and is 80 mils vice 60 mils of the RAAMat. If you join the Ed forum you can find a 20% off code for all eDead products.
3.7L Nitrous Breathing CL
I used about 200sq ft of edead v1se2 60 mil.I've gone over the car completely with 2 layers atleast ,making it 120 mil think and most of the trunk now is got 3.Almost a year its been on ,threw all seasons and no pelling no bad smells and pretty easy to install.http://www.cardomain.com/ride/3152723
Summer is Coming
Summer is Coming
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
eh it's no biggie if the car is level and no wind lol it will stay up. But I never pop my trunk when ppl ask what I have I tell em a jensen 10 and they just look and say for real lol
AcuraKidd
04-23-2007 06:33 PM
ReflexRacing_com
10-24-2002 12:49 AM
ZeroPSI
06-20-2002 05:22 PM
