Driver Door Lock Probelm
Old Nov 5, 2002 | 01:09 PM
jayo_75287's Avatar
Unhappy DriverS SIDE Door Lock ProbLEm
I HAVE A 99TL WITH THE FACTORY KEYLESS ENTRY SYSTEM. MY DRIVERS SIDE DOOR PIN ISN'T WORKING CORRECTLY. IT WILL NOT LOCK OR UNLOCK WITH THE REMOTE OR THE DRIVERS SIDE OR PASSENGER SWITCH. YOU MUST EITHER USE THE KEY OR MANUALLY PUSH THE PIN DOWN OR PULL IT UP. IF THE DRIVERSIDE PIN IS UP AND ALL OTHER DOORS ARE LOCKED. I CAN USE THE REMOTE TO UNLOCK THE OTHER DOORS, BUT IT WILL NOT LOCK THEM AND ARM THE ALARM UNLESS THE DRIVERS SIDE PIN IS IN THE LOCKED POSITION. IS THE PROBLEM A BAD RELAY. AND IF SO, WHERE IS IT LOCATED. IS IT IN THE DRIVERS SIDE DOOR? HELP!!!!
ALSO, DOES ANYONE HAVE AN ACTUALL WIRING DIAGRAM OF THE SECURITY SYSTEM. NOT A WIRE COLOR CHART..
rockyboy
Aug 4, 2024 10:35 AM
tman570
Jun 11, 2019 07:56 AM
VA2000TL
Oct 2, 2015 08:26 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
michaellong77
1G CL Problems & Fixes
Sep 11, 2015 12:54 AM
