Double Din questions
I want to get a double din for my TL. Right now I'm leaning towards the Pioneer AVH-P4000DVD. Or if you guys any other recommendations (~$500) I'd appreciate them.
So, I'm going to get a universal double din kit from uncald4 and have it installed. I don't know where yet, I have to find a good place.
Now, can I still use the stock audio system? I have absolutely no extra money to spend on new speakers or subs or anything.
Thanks!
Thanks!
Former Sponsor
All your speakers will work fine. No crazy adapters or tricks. However, your installer will need to wire in an RCA pigtail to the BOSE subwoofer signal wires. It's very easy and work awesome. You'll be able to use the subwoofer control on your Pioneer to control the level of the OEM sub.
I would definitely stick with the AVH-P4000. Great unit. Here is the link for wiring in that RCA pigtail.... https://acurazine.com/forums/audio-video-electronics-navigation-22/keeping-factory-sub-when-adding-aftermarket-headunit-99-03-tl-326253/
Right you are.
I would definitely stick with the AVH-P4000. Great unit. Here is the link for wiring in that RCA pigtail.... https://acurazine.com/forums/showthread.php?t=326253
And thanks for the help so far, guys!!
I would have a general idea of whats going on either way but most likely if you tell them what ucald said I'm sure they will know what your talking about assuming they know what their doing lol
Former Sponsor
Right. A good installer should know what they're doing on this car. However, there is not harm in you guys talking through it. As a customer you always need to voice your expectations. Maybe read through that DIY subwoofer thread in the audio/video forum and write down or print the wire colors and location info for the installer. I'm sure it would be appreciated.
I called up a few shops and I found a perfect one today, Stereo Masters, in Pasadena, CA. Before I even mentioned the subwoofer problem he brought it up. And we talked it through. He knew what he was talking about too. So once I order this I'll be going with them to have this installed.
Is there anything else I need to order, installation wise, besides the dash kit?
Does the P4000 have a sub input? If you click on 'more images' and look at the picture of the rear. I don't see a sub input...
http://www.pioneerelectronics.com/PU...s/AVH-P4000DVD
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
