Dom's Navi to DVD Install
Old May 11, 2005 | 04:05 PM
TSX559's Avatar
I just finish installing my converter today. It looks like it works. I just have to hook up my DVD player to it now. Got some pics but dont know how to post them. I put the unit up front. I tapped into the pin connector under the right side kick panel. Theres a grey and white connector there. The one you tap into is the white one. And you cut the 4 wires and connect it to the converter. Pretty easy install. I did it in 40 minutes. I just taped it to see if it works and it did. So now I have to go back and solder it in.
Big ThANKS to tjt889 for telling that the connector is in the kick panel.
Old May 11, 2005 | 04:45 PM
TSX559's Avatar
Pic 1
Pic 2 Pic 3 Pic 4
Pic 5 Pic 6 Pic 7
Old May 11, 2005 | 04:51 PM
TSX559's Avatar
I will post more pics of the screen when I get home and install the DVD player. But everything looks good right now.
Old May 11, 2005 | 05:17 PM
CJams's Avatar
Guinea Pig
Good job! Now how about the sound?
Old May 11, 2005 | 05:51 PM
TSX559's Avatar
The sound is going to be a FM modulator for right now. planning to get a blitzsafe later on.
Old May 11, 2005 | 06:55 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Do you get any inteference in the video screen when the engine is on and you are moving?
Test for this before you put everything back togther, just to make sure.
Looks like you just about got it though. Congrats!
Old May 12, 2005 | 10:55 AM
TSX559's Avatar
I think i did. you can barely notice it tho. the screen shakes a little. moving up and down. but i have to double check on that. if it does do that with the engine on, im going to put in my inline power filter. do i put the filter on the DVD power or the converter power? hopefully that will stop it. i just need to find a spot to hide the unit now. i like the unit up front then in the back. Acura wont even no that i cut the wires. it looks just like stock when i taped it up. i have pic's on that.
Old May 12, 2005 | 01:48 PM
TSX559's Avatar
hey tsx536, where in central cali are you from?
Old May 12, 2005 | 03:05 PM
TSX559's Avatar
everything is done. no lines on the screen at all. i just hook up one inline filter to the dvd and converter unit.fm modulator sucks tho. buts its ok for right now. diffenately recomend getting a blitzsafe or soundgate. picture is really clear too. THANKS DOM
Old May 12, 2005 | 03:18 PM
TSX559's Avatar
here it is
and wires taped up to look like stock. just need to put the kick panel back on to cover it up. dealer wont even know its there.
Old May 12, 2005 | 03:21 PM
Can you please let us know what inline filter you used for the DVD and where you got power for DVD and the module?
Thanks.
Old May 12, 2005 | 03:38 PM
TSX559's Avatar
Thanks.
i got power for the dvd at the amp acc wire. just tap into it. and i just use an inline filter that i have for a while already. i dont no what kind it is. i got it at an electronic store. it has some kind of blue hard heat shrink on it. i dont no if its a good kind, but elduderino will know what it is.
Old May 12, 2005 | 03:49 PM
Tsx536's Avatar
Rep'n Taxbrain.com
^^ Lookin' good man! Congrats!!
I'm around the Sacramento, Stockton area. So like 2-3 hours north of you.
Old May 12, 2005 | 04:48 PM
TSX559's Avatar
Thats cool. not too far away. any questions on my install just let me know.
Old May 12, 2005 | 05:03 PM
CJams's Avatar
Guinea Pig
can't wait to get mine! Looks good! Do you have a tv tuner? Or just a dvd player?
Old May 12, 2005 | 05:25 PM
TSX559's Avatar
Yeah thats sesame street. i just have a dvd player. planning to get a new unit later on. a dvd player with a built in tv tuner. i do recomend that you get a aux input instead of using a fm modulator.
Old May 13, 2005 | 07:10 PM
I think I am in trouble
I soldered almost all the wires but have the problem with two:
I have one brown wire that goes from the screen to the navi (this one stayed, I did not cut it)
Another one left is BLUE from the Navi screen and Yellow from the Navigation Unit
Should I solder them two (blue & yellow) or am I missing something here...
PLEASE HELP ASAP
Its 2002 TL
Maybe this will be more clear:
Per instructions:
White (pin A4) = Red wire on the RGB
Red wire (pin A5)= Green wire on the RGB
Yellow wire (pin A10)= Blue wire on the RGB
Green (pin A11)= Gray on the RGB (sync)
Ground the Black and Shield wire in the DB9 Cable.
As you can see BLUE wire (from the screen) in not mention here... the only one that we did not use in this step
“YOU MUST CUT THESE WIRES IN HALF!!!! LEAVING YOU WITH A NAVIGATION SIDE AND A SCREEN SIDE
Red, Green, Blue and Gray wires on the DB9 cable go towards the Screen.
Orange (Red mate), Yellow (green mate), Purple (Blue mate), and Brown (Gray mate) goes towards the Nav unit.
Yellow (from the NAVI unit) is the only one that we did not used in this step...
So my question is- should I solder BLUE and YELLOW TOGETHER?
PhillyTL-S is online now Reply With Quote
Old May 14, 2005 | 07:10 AM
You can ignore my previous post about the wires ( I was completely wrong + it was 11PM) never start your project so late
I will post some pictures after I finish today.
Old May 14, 2005 | 10:12 PM
NFLblitze1's Avatar
Youse Gots Sacked
did you put in an aux. input? how much did it cost?
Old May 15, 2005 | 03:26 AM
Akim711's Avatar
dynamic Duo!
hey man..
nice install... the pictures alone doesn't seem to say much about the steps of your install, but yes its tough to stop and take pictures of your progress when the only thing on your mind is to complete your project (at least I had that problem).
also if i may add some advice: Unless you're pretty fast or just a natural when it comes to installs, you might want to just save your time and get the blitz adapter now, instead of getting an FM modulator for now and switching it out later. I'm sure that by the time you read this you probably already have noticed this, but fm mods the gain is just too damn low... plus the blitz just plain sounds better....
Old May 15, 2005 | 09:16 PM
kaliraver69's Avatar
TSX559 didn't you have the Avic-n1?
Old May 17, 2005 | 11:39 AM
TSX559's Avatar
Nope. not me. i think that was TSX536.
Old May 17, 2005 | 11:42 AM
TSX559's Avatar
Originally Posted by Akim711
hey man..
yea i no. i almost forgot to take pictures too. and yea. im going to get a blitzsafe. just been really busy right now. i do recommend that for other people as well. DONT EVER GET A FM MODULATOR. IT SUCKS BAD.
Old May 24, 2005 | 10:08 PM
CJams's Avatar
Guinea Pig
So did you put the unit behind the kick panel? And the inline filter you used....where did that go?
Old May 24, 2005 | 11:56 PM
BlackTSXer's Avatar
Teh seX
anyone know if there are a working batch of blitzsafe adaptors out yet? last i heard was there was a bad batch?.. and if so what's the part #? i keep hearing people saying use the search, but i just come up with tons of pages i cant sit and read all day.. thanks
Old May 25, 2005 | 12:37 AM
elduderino's Avatar
VP Electricity
Four words.
Evelyn
Wood
Reading
Dynamics
OK, just kidding; ) No known way to tell the good from bad from the outside, but the last one I bought from Soundgate is fine. If you have non-nav, the SOundgate works just fine.
I heard the Blitz comes with the cable for Nav units. IF this is correct, then it's worth getting if you don't want to do the cable mod described in the FAQ section.
Old May 25, 2005 | 08:22 AM
CJams's Avatar
Guinea Pig
This is the best I have heard thus far.....
"PIE is coming out with an X3 part. It is an X3 brain and X3-HON03 harness. This is a new part and none are available at this time. Projected availability is 1 month. The part is similar to http://cgi.ebay.com/ebaymotors/ws/eB...category=38636. "
elduderino is conjuring up a soundgate aux 3 adapter that may be plug and playable, but I don't think it has made it through R&D yet.
But as of yet.....I haven't been able to find the perfect adapter for sound. Most people have had problems losing the upper level highs with other adapters, or they lose XM, or something. Our cars are just too damn new to have easy mods done for the audio.
Old May 25, 2005 | 08:23 AM
CJams's Avatar
Guinea Pig
sorry...as far as blitzsafe adapters--the new "good" batch should be in stock between now and the next week or 2
Old May 25, 2005 | 10:41 PM
BlackTSXer's Avatar
Teh seX
thanks for the info.. cause i still havent installed dom's navi module because i have no audio source and am not settling for an fm modulator
Old May 26, 2005 | 08:54 AM
CJams's Avatar
Guinea Pig
Same here....Doms navi module is sitting next to my Alpine TV tuner and amp in the office. elduderino is working on using Soundgates aux3 with a home made cable to make it plug and play, but he is unsure of the sound quality as of yet.
Old May 31, 2005 | 08:47 AM
CJams's Avatar
Guinea Pig
I just wanted to let everyone know that I used this pic as a quicl reference and it didn't work for my 05tsx...
I had to connect my wires exectly opposite of this pic in order to get the video input to work....(Red, Blue, Green, Grey) towards the screen (away from the white plug) and (Yellow, Orange, Purp;e, etc) closest to the plug.
Also, still having some minor issues...
1. Since I unplugged the Navi screen I can't use the Navi without entering some type of security code. How do I find out what my security code is? I haven't had time to search the threads for this yet, and I am at work so I don't know if I will get to today.
2. It may be because I haven't typed in my security code, but when im watching a dvd the screen cuts out after a minute or so. It seems like a screen saver kicks in or something. I have to hit a button, like audio or something to reactivate the screen. It acts like the "nag" screen with the OK button when you don't select OK, it shuts off after a minute or so. Should this stop once I enter my code and hit the OK button?
3. Where is everyone getting the 12v power for the Nav2DVD unit? And what type of filter should be used?
4. The black wire and the uninsulated silver wire, should they be twisted together and grounded to the chasis? Can I ground the units ground to the same spot?
A little help would be appreciated. Thanks all!
Old May 31, 2005 | 03:15 PM
BlackTSXer's Avatar
Teh seX
soo i am assuming that the picture above is an install of an 04' tsx?
Old May 31, 2005 | 07:04 PM
Kazzaf's Avatar
When u bought the car. If brand new there should be a card in the glove box code for Navi and CD player is on there.
Old Jun 2, 2005 | 12:26 AM
dailo's Avatar
I bought this unit as well, however I have the Ice-link that uses no blitzsafe adapter, can I use the blitzsafe for the ice-link and the dvd converter??
Also is this installation hard? I'm pretty interested in getting this setup. Also which alpine unit were you referring to that has a tv tuner and dvd player built in? Thanks!
Old Jun 2, 2005 | 09:47 AM
CJams's Avatar
Guinea Pig
I bought the alpine TUE-T151. It is only a TV tuner! A seperate little box that attaches to 2 antennas, a video and r & l audio output, 1/16" remote eye (sold seperatly dammit!), and a power and ground and optional remote wire. I plan on using a PS2 slim for my dvd player.
blitzsafe maybe for ice link? Not for dvd converter!
Old Jun 2, 2005 | 03:55 PM
dailo's Avatar
I meant if I could use both devices at the same time? Because I have the Ice-link installed, but if I want my dvd player to go through a blitzsafe instead of FM transmitter would it be possible? Thanks.
Old Jun 2, 2005 | 04:15 PM
dailo's Avatar
Also where are you guys plugging the power inverter? Are you using the cigarette ligher in the arm rest or is there a wire somewhere else or socket where a power inverter can be plugged into? Thanks.
Old Jun 3, 2005 | 10:37 AM
CJams's Avatar
Guinea Pig
Power inverter? I used the yellow and red wire going to the oem amp. Man I wish my cigarette lighter had power all the time and not just when the key is in the ignition. I might have to change that. Ye Ole Cig Lighter Mod!
Old Jun 3, 2005 | 11:01 AM
elduderino's Avatar
VP Electricity
1) Does the icelink w/o the blitzsafe have an RCA audio out? (I haven't seen one yet and was curious). IF it does, you just need an RCA source signal switcher like the Soundgate AUX3. If it DOESN'T, that's a kink...
2) The PS2 needs 110V AC, so you need an inverter.
