DOM DVD help!!!
Bit*h get in my car
DOM DVD help!!!
I have an 04TSX with Nav and am attempting to remove the little tray above the "not an ashtray" tray...The links in the DIY are broken. Any help here would be appreciated.
Another questions is on the DOM NAV to DVD console, there is a black and red wire and a blue and white wire. The black wire I think is for ground and the red is for power...If this is correct, are the blue and white wire not needed? is that only for the back up camera?
Any help would be appreciated...if anyone has done this in their tsx any pics would help! Thanks everyone.
I'm Baaack!
Been a while since I installed mine, but I think you're right. The Blue and White should have a sticker on them, but I think they're wired to the reverse lights for backup camera power on when you put the car in reverse. If you don't have a camera installed you can just tape them out of the way.
Bit*h get in my car
Ok I have succesfully installed the DOM Nav to DVD unit and I have the blitzsafe and everything but I hear this like interference in the background when I play movies...I thought the blitzsafe was supposed to eliminate that???? Any help or suggestions???
Received 3,747 Likes
your going to need a ground loop isolator which you can pick up at radio shack. plug it into the blitzsafe and then plug the audio cables into the ground loop isolator.
BoricuaTL
04-08-2016 01:08 PM
