Disabe Navi Auto Power Down??
Have any of you guys figured out a work around for the navi's auto power down when using your external dvd on navi setup when the car isn't running?
All I can figure is to keep the car in the "ON" position instead of the accessory position.
Any thoughts?
Any thoughts?
Turn Signals are good!
I dunno, track down the power wire and run it to the "acc" position on the switch maybe. Then at least it will be on with just your radio, and not everything in the car.
Yeah, I guess that's what I could do, but I would need to know the which wire is the turn on wire for the navigation screen.
Can anybody help me with that?
![](http://home.cox.rr.com/gmanchu/navi.jpg)
![](http://home.cox.rr.com/gmanchu/navi01.jpg)
![](http://home.cox.rr.com/gmanchu/navi1.jpg)
![](http://home.cox.rr.com/gmanchu/navi2.jpg)
![](http://home.cox.rr.com/gmanchu/navi3.jpg)
YES
actually, i run my PS2 on my screen when i'm at car shows, and i DONT have the car on!!!
what you do is turn car to ACC so that power goes to the nav screen, power up your PS2 or DVD player, then unplug all three brackets from the BACK of the DVD ROM in the trunk! since power was already going to the screen, it will stay on without shutting off after 5 minutes!
trust me, this is what i do at the car shows, but you just have to do it in that order which is to unplug the 3 harnesses from the back of the ROM AFTER the screen is already powered up and your car is on ACC
Cool... That sounds like it will work. Though I might even want to permanently disable the autoshutdown on the screen. Perhaps if I just were to cut one of the wires coming from the dvd rom? I dunno, do you think there's a way to do that so I don't have to get into the trunk every time? (got a big speaker enclosure that makes it difficult to get to dvd rom)
I was thinking about this... it's not going to be practical for me to reach into the trunk to grab that connector, since my speaker box completely covers the access hole in the back seat.
So I guess I'm trying to understand what is happening so I can disable it.
Unplugging the dvd rom and the screen staying on sounds weird to me. Not to say it doesn't work as described, but I would think that there is a wire sending a 'stay powered up' signal to the screen. This would be consistent with how a turn on lead works on an amplifier. Unplugging the whole thing would turn the screen off.
So, if there is no conventional 'turn on lead', then is the dvd rom sending a second signal to tell the screen to shut down? If so, which wire do you think it is using? Or do you think something else is going on?
Hey Jeff...
Is it possible to just put a 4pdt relay in place of the switch for the navi mod? I mean..can i forego the switch, keep everything in the trunk and just have the dvd player kick on the relay and switch all the connections? I thought this way I could just have the dvd in the rear console, and just the run the shortest possible amount of wires.. Now..hmm how to make my remote see thru the closed console lid..hmm I guess a remote IR plug n receiver from my TIVO might do the trick..lol
Did anyone else try it with just a relay? I was curious if the relay coil energizing process would cause any kind of transients or spikes..I'm sure it would be nominal..but you never know..
Steve
Steve
Yes! Exactly what I was thinking... The relay does the exact same thing as the switch, just remotely.
I already bought the relay, and will be hooking it up that way this weekend.
BLK^5 here on the forum has it hooked up that way and it works beautifully.
I'm all into running as few wires as possible to the front.
STEVE
Just finished up in the garage... and the navi conversion works great! Modified the AVC-RBG1 and installed it. And everything worked the FIRST time. I can't believe it!
Used a relay in the back run to a switch under the dash in the front. Works beautifully.
Now if I can just figure out the why my PS2 is making noise.
THANKS TYPESDRAGOON! You da man.
HydrasunGQ
09-14-2015 10:14 PM
lovic87
09-09-2015 10:18 AM
asahrts
09-04-2015 05:55 PM
