Default Navi Code
Old Nov 12, 2005 | 04:24 PM
awraynor's Avatar
Default Navi Code
The 01 CL-S I purchased is still set with the previous owners defaults. The dealer said he would contact the previous owner and get her code so I could reset the personal address etc. He did not supply the codes and only took 5 months for a title. Is there a default code so I can personalize my navi unit or will I have to pay a dealer for this?
Thanks in advance for your help.
Old Nov 13, 2005 | 09:10 AM
kjjust's Avatar
4th Gear
awraynor....the way I was able to get into my "user 1" setup was to use the navi anti-theft code as the pin. hopefully, you have both the radio and navi anti theft codes, if not, they are suppose to be on the side panel of the glove box, or on a card issued with the car manuals. Otherwise, you will have to get the code(s) from the dealer using the VIN. I am not sure, but it may have to be the original dealer who has the codes..hope this helps.
Old Nov 13, 2005 | 10:18 AM
GIBSON6594's Avatar
My Garage
I don't see you being able to get the codes from a dealer, unless the original owner gave them to the dealer. If was the old owner I wouldn't want someone to have access to all my stored addresses and info.
You'd probably be better off having the dealer reflash the navi to the factory specs to erase all of the old info in there and you can start fresh with it
Old Nov 13, 2005 | 09:28 PM
kjjust's Avatar
4th Gear
Gibson, I got the navi anti-theft 4 digit code from the original dealer, and entered it as the user1 pin as per nav handbook, and I was able to access all of the previous owners' saved destinations as well as their home address....so when you "sell" yours, you might want to delete your saved destinations as well as your "home".
Old Nov 16, 2005 | 08:47 PM
awraynor's Avatar
There was no card with the car and I did not see a sticker on the side of the glove box. I called the dealer to see if he could look it up by VIN and he said it has to be the code off the rear of the NAV dash unit. That of course will be one hour of labor for removal and reinstallation. I am getting more frustrated with this car and ACURA everyday I own it, not that I don't still love the car mind you.
Old Nov 29, 2005 | 12:08 AM
OneFlyCL's Avatar
Yea i have the same problem too.....hopefully you get this figured out with because i dont wana take my whole dash off for the pin.
Old Nov 29, 2005 | 05:43 PM
blaser's Avatar
I found something interesting yesterday.
The code for the radio and nav are written on teh fuse box cover.
The box under the hood.
Old Nov 29, 2005 | 06:15 PM
OneFlyCL's Avatar
I just found it and it works HAHAHA! I took a picture hopefully this helps you
I hope this works i m a newbie
Old Nov 30, 2005 | 08:22 AM
awraynor's Avatar
Not as lucky as you guys. No sticker on the glove box or the fuse box!
Old Dec 1, 2005 | 02:42 AM
OneFlyCL's Avatar
dam good luck than man, i'll let u know if i find anything else
Old Dec 1, 2005 | 02:59 PM
awraynor's Avatar
I did find this site when looking for some info on the radio codes. If it is real, it looks like it can save you some money.
http://hondaunlockcodes.homestead.com/
Old Dec 2, 2005 | 02:36 AM
OneFlyCL's Avatar
if you're looking for the radio code you can try this https://acurazine.com/forums/showthread.php?t=170663
i dont know if it works though so good luck to you
Biggie_B
May 27, 2025 05:51 PM
Jamus22
Jun 11, 2023 10:08 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
Cgannotti
Sep 25, 2015 05:04 PM
