The correct way to bypass the TSX audio amp
Did someone delete this thread? Good thing I saved the .mht files. haha
Originally Posted by Chad05TL
(Post 11168039)
I think you selected the wrong place to post in... :tomato: |
you appearantly dont remember the thread called "The correct way to bypass the TSX audio amp"
(Post 11174918)
Neither do I. Perhaps in was in the Audio sub-forum. :confused: |
possible but I kinda doubt it because I just did a fast search and couldnt find it and plus my link does not work that used to point to it.
Chad, I'm looking for it also. Any luck in finding it? Can you email me the mht files to mitsu2k@gmail.com please? Thanks!!
sent
Originally Posted by mitsu2k
(Post 11789834)
thanks tsx family |
sent
(Post 11820885)
sent
HAHA |
I would like to receive it too please madhouse1616@yahoo.com Thank you
yeah me too. stenmeister3520@gmail.com thanks bro
could i get it as well? mtbiker055@yahoo.com
try this link
http://home.roadrunner.com/~chad97z/...0Community.zip |
Chad you're the man! thank you.
i would also like this, please and thank you
I dont plan on keeping this posted forever. I mean if Acurazine doesnt, then why should I? I'm just a squirrel.
try the link above again btw, if you are wondering why the mht file hands when it loads, its because this website is plagued with ads. |
hmmm, doesnt seem to be working.
would appreciate if you could send it to rstrieter94@yahoo.com -Thanks |
Thanks Chad
If you ever check this, I would greatly appreciate it if you could send it to me as well, rhannahs@gmail.com.
Thanks so much. |
Whomever can get me the info i need from that old post i will paypal them money. Ive tried high and low to contact mercman no.luck. I need those instructions to attempt to make.my own. Please ill paypal money for the thread
MV1Luv, Those instructions are not going to get you a clean signal. There was a big fued about mercman posting up those false instructions. His harness actually has a small simple circuit in it that makes it noise free. I used his instructions only to get a noisy signal. It wasnt super noisy but noticible.
I'm in the same dilemma. I want to bypass the factory amp and getting one of those harnesses probably isn't a possibility. Do I have any options?? Help please!
so i take it no one is mechanically inclined enough to test the wires from the factory amp?? there is only two plugs coming from the factory amp one is the output to the speakers and the other is the input to the amp from the head unit. if you want the speaker colors i can give them to you just let me know
It would be great if someone could provide the colors for the audio input to the amp. I am going to bypass the amp the correct way and run the audio signal into a line out converter made by audiocontrol but not can't find a clean wiring diagram for the bundle leaving the navi going to the amp. Any help?
Can i get it if someone has it please
Originally Posted by Bearcat94
(Post 11175685)
:confused: josueandrade2112@gmail.com |
| All times are GMT -5. The time now is 11:40 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
