TSX: Convert XM to Sirius WITH TECHNOLOGY PACKAGE
Old Aug 13, 2011 | 12:19 AM
Joeya527's Avatar
5th Gear
Smile Convert XM to Sirius WITH TECHNOLOGY PACKAGE
Hi all, been looking all over and trying to get definitive answer. Can you convert the xm radio to sirius in your 2006 Tsx that HAS the technology package? Any help or advce is greatly appreciated.
Old Aug 13, 2011 | 08:41 AM
Ron A's Avatar
Administrator
Welcome to the forums.
Since TSX doesn't have its own Audio/Video subforum, I moved your thread here, and deleted your other thread in the tSX Forum.
Old Aug 14, 2011 | 12:40 PM
zerepdivad's Avatar
This... http://www.pac-audio.com/productDeta...&CategoryID=47
Along with an SCC1 tuner should do the trick. May want to call them and verify though.
Old Aug 16, 2011 | 10:49 AM
Joeya527's Avatar
5th Gear
Smile Thanks
Thanks although I am still a little confused.
I'm not sure if I need to use these iSimple products or can should use Honda and Acura HONSC1 and SCVDOC1 Package along with a single antenna converter to change the stock XM antenna to accept sirius.
I want to continue to be able to use my CD changer as well as use my Stiletto 2 as the receiver so I don't have to change units.
Any additional thoughts are welcome and thanks again for the link! I am going to email them and get their thoughts as well.
Thanks!
Old Aug 16, 2011 | 10:30 PM
zerepdivad's Avatar
Thanks!
Wait so you just want to use the stilleto 2 as your unit? not actually integrate it into the factory radio?
If sao all you'll need is a sirius fm modulator (FMDA25), and the stilleto 2 vehicle kit.
Old Aug 17, 2011 | 11:13 AM
VicTL06's Avatar
I called them about this for my TL and this indeed does the trick. What I realize in hindsight is that I should have also asked if the OEM XM antennae works with the SCC1 tuner. So I contacted XM (Canada, mind you) and they confirmed that the OEM XM antenna will work with the SCC1 tuner.
Old Aug 17, 2011 | 10:55 PM
Joeya527's Avatar
5th Gear
Smile
Thanks everyone. Let me give some additional background.
What i want to do is connect my stileto 2 to my car so i can use the navigation screen to change the channels on the stiletto 2. Remember i dont want to use the SCC1 as i want to continue to use the Stiletto as the tuner (more on the reasoning below).
From continued research i think i have two options one being more risker than the other:
Option 1(seems safer)
I take out the xm tuner in the trunk and replace with the HONSC1 and then connect the HONSC1 to a SCVDOC1 which i would connect my Stiletto 2 to.
Here's the link to the combo package of the honsc1 and scvdoc:
http://www.tss-radio.com/products/ho...cvdoc1-package
Option 2 (more risky)
This would entail purchasing ISHD571(instead of the HONSC1) and then hopefully connect that to the Scvdoc1 (but i cant get anyone to let me know if the ishd571 will connect to the scvdoc1 and allow control of stiletto via dash). The advantage of this set up would be I would be able to connect the Stiletto as well as my iphone all being controlled from the nav screen (at least that is the goal!). Here's the link to these two products:
http://www.pac-audio.com/productDeta...&CategoryID=36
And
The reason for this is that i currently have the Stiletto 2 hooked up on my dash via vehicle kit via Aux cable (or i can use fm modulator in car dock and tune into station) and cigarete lighter and antenna and it looks terrible. I know i could get it powered but it would still be sitting on my dash along with the antenna. Wouldn't it be great if i could use the Stiletto but control it through the dash? (i don't want to have to move my sirius subscription to a new tuner as i have a lifetime (dont want to use a switch) and also lose the portability of the Stiletto more importantly. (again don't want use SCC1).
Hope this helps. Any persons out there knowledgable about this stuff i would love any advice or additional insight.
Thanks everyone and have a nice night.
mlody
Dec 4, 2019 02:11 PM
baelim
May 10, 2018 09:53 AM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
Dman00tl
2G TL Photograph Gallery
Sep 25, 2015 10:34 AM
