Connecting a 200uf capacitor to remove bass
Old 10-13-2007 | 10:33 AM
EuroDude2k's Avatar
I have some 5.25" speakers in the car doors, running of a small Amp.
The issue is that the speakers are outputting too much bass, causing them to distort and vibrate the doors when bass is played. (The Amp only has a LPF :o I need a HPF)
So Ive bought some 200uf 100v BiPolar Capacitors to decrease the frequencies below 200hz
I tested the capacitor inline of the (+) speaker wire, and it indeed works
Now the question is, the front Speakers are 2-way Boston S55 (non component), which already has a built-in capacitor/inductor for the tweeter.
Q. Can both the tweeter driver and midrange driver both run off the new capacitor? Can I simply place the capacitor inline from the Amp to the speaker? will that cause any problems? (ps. the tweeter still functioned ok when I tested it, so it should be fine, correct?)
Or do I need to re-wire the speaker itself and connect the 200uf capacitor from the (+) Y point to the (+) of the driver (where it splits the + to the tweeter and mid-driver), so the tweeter doesnt have anything to do with the 200uf capacitor?
Here's a diagram:
Old 10-13-2007 | 08:32 PM
mercman's Avatar
You would be hard pressed to hear any difference between the two configs. The large 200uf cap will have negligible affect on the small tweeter cap. I can post the formula of series capacitors if you like.
jeff
Old 10-14-2007 | 07:48 AM
EuroDude2k's Avatar
Ok, good to know. I just needed to make sure the caps running in series wouldn't change the ohms to the tweeter or something like that.
No need for a formula, I'm happy with the results.
Cheers.
navtool.com
31
11-16-2015 08:30 PM
joflewbyu2
10-08-2015 11:16 AM
navtool.com
09-25-2015 05:15 PM
ROSSARONIE
09-22-2015 11:46 AM
Quick Reply: Connecting a 200uf capacitor to remove bass
