Concealed Display Valentine-1 Installation: Step-by-Step Instructions
The Voice of Reason
Concealed-Hidden Display for Valentine-1 Installation: Step by Step Instructions.
I’ve completed hardwiring my V-1 and mounted the hidden display in the space in the console formerly occupied by the fuzzy red coin tray that we in the PC USA get in place of an ashtray. At most this requires sacrifice of the coin holder or ashtray, well worth it IMO. To each his own vice. My main V-1 unit is located in the pocket of a Case Logic visor organizer ($7.99, Target Stores), the cord is routed down behind the trim of the "A" pillar, behind the glove box and into the console. The power source I used is the wires for the front accessory power socket connector. It’s a pretty neat setup, completely invisible if you close the door of the coin pocket holder!
Standard dIsclaimer: This is how I did it, I don’t know if your skill level is greater or less than mine, so I don’t necessarily recommend that you attempt this. So if you try this and break something or blow anything up or maim kill or disfigure yourself you’re on your own!
I also installed the cassette tape player when I was doing this, many of the same pieces need to be removed. http://www.hondacuraworld.com/ has instructions online.
Additional Tools:
Thin-blade putty knives
Dremel Moto-Tool
Helms TSX Service Manual (HIGHLY recommended)
Additional Materials:
V-1
V-1Concealed Display
V-1 Wiring harness
3M wire taps
HD Velcro pads
1 Case Logic Visor Organizer
1 Sheet black felt
7’ Telephone cord
1’ Telephone cord
Cable ties
Electrical Tape
Duct Tape
Masking tape
1. DISCONNECT BATTERY!!!!
2. Pull down weather strip on front edge of passenger’s door frame
3. Pull up front pillar cap on “A” pillar and pull off “A” pillar trim
4. Remove glovebox stops.
5. Disconnect glove box damper.
6. Pop off side cover of dashboard
7. Remove screw and pop off side cover of console in passenger’s footwell.
8. CAREFULLY remove console storage box (pulls out), Don’t pull on lid.
9. Unscrew shift knob.
10. CAREFULLY remove console top (pulls up)
11. Disconnect seat heater switches.
12. Remove 4 Phillips screws from coin pocket holder assembly.
13. Disconnect power socket connector. Remove Coin Pocket Holder.
14. Note that head airbag occupies top 1/3 and rearmost 1/2 of “A” pillar. Leaving about 10-15 cm. of slack cord, duct tape one end of 7’ telephone wire forward of airbag assembly. Route wire down A pillar in front of trim clip holes, again keeping on place with duct tape. Route wire into dash, behind glove box and into center console.
15. Pop red felt coin holder out of assembly.
16. Using Dremel, cut approximately 1” diameter circle in back of coin pocket holder
17. Drill 2 approximately 1mm holes below the 1” hole. (These will be used for a cable tie.)
18. Now is also a good time to cut a cardboard template for the felt piece to fill the tray. (You may wish to cover the wires visible behind the concealed display.)
19. Unwrap electrical tape from power socket wire. Press 3M wire taps into wires. I modified the V-1 wiring harness by adding a second spade connector. Insert spade connectors into wire taps, wrap everything in electrical tape.
20. Plug 7’ and 1’ telephone cords into V-1 harness.
21. Pull V-1 fuse holder thru 1” hole an into pocket of coin holder assembly. Secure with cable tie.
22. Pull 1’ phone cord thru hole.
23. Attach HD Velcro to V-1 Concealed Display and coin tray assembly.
24. Plug telephone cord into V-1 display.
25, Replace 4 Phillips head screws for coin pocket holder assembly.
26. Cut black felt to size to cover unsightly bundle of wires.
27. Cut 4 cm. slit in the top of the Visor Organizer at the leading edge for the visor mount and a 1cm slit on the window side for the cord. Cut a “window” for the front LIDAR detector (microwaves will travel through the material, LIDAR won’t. I also glued black nylon netting over the “window”.
28. Mount visor clip on visor.
29. Mount visor organizer on visor.
30. Insert cord thru hole.
31. Slide V-1 into visor bracket.
32. Plug telephone cable into V-1.
Next, as they say in the Haynes manuals “Reassembly is the reverse of disassembly”!
Additional Tools:
Dremel Moto-Tool
V-1
V-1 Wiring harness
3M wire taps
HD Velcro pads
1 Sheet black felt
7’ Telephone cord
1’ Telephone cord
Cable ties
Electrical Tape
Duct Tape
Masking tape
Future Seminole
1 Post
21_in_AZ...
_*CG/Quartz*_-_*Navi*_ _*5at*_
2" drop
shaved "acura" & "tsx"
OBX full catback system
Red Calipers
Custom Front Grill
im intrested in seeing pics of ur car, specially the custom grill, cause i wanna get one, and maybe its just cheaper to make my own....
2" drop
Red Calipers
Custom Front Grill
The Voice of Reason
Originally posted by 21_in_az
the only cam i have is a digi cam on my cell phone, i can get pics but how do i upload them to this site?
I'm also "finished" but not quite FINISHED with the remote display mounting! When I go digital I'll post some pix.... I think I already know what my wife is going to get for a Christmas present!
Do I Make You Horny?
Im not sure if anyone is still reading this post or not, but i did post some real quick pics under
GALLERY...................than under "FINALLY"
hopefully, i will be posting better pics this weekend.
ITSJESTER
17
12-06-2018 02:29 AM
