CLUofI - last one, i promise
Old Apr 8, 2002 | 08:37 PM
nokio's Avatar
So, for two image dynamics subs pushed by 2000 watts rms, what enclosure should i do?
infinite baffle sucks, bandpass would shatter, so just have them sealed facing the trunk?
Old Apr 8, 2002 | 08:42 PM
CLUofI's Avatar
337
2000 watts would kill any other enclosure. If you are building it your self, build it heavy, with glue and screws.
Any one else have some input to add?
Old Apr 8, 2002 | 10:38 PM
Nicky Pass's Avatar
Fuct in the hed!
I'd use 1" thick MDF as opposed to .75".
Old Apr 11, 2002 | 11:44 AM
99CL2.3's Avatar
Nicky is dead on, use 1". There's only a nominal price difference between the 1" and 3/4" also. Just make sure you compensate for the difference in internal volume if you already calculated for 3/4". Make sure you use the Thiele-small parameters in your calculations. Also, I've found that some subs don't like a shallow box regardless of volume. You're gonna want to caulk the hell out of the seems on the inside too.
Old Apr 11, 2002 | 02:01 PM
spiroh's Avatar
First of all which ID sub are we talking about? The only one that can hadle 1000w to each speaker is the ID MAX. use a 1.25-1.5 cu ft box for each of them.
spiro
Old Apr 11, 2002 | 02:04 PM
nokio's Avatar
yeah spiro
2 12" Image Dynamics IDMax's with 2 1000d crossfire bmf amps
Old Apr 11, 2002 | 02:08 PM
nokio's Avatar
BTW
can anyone help me out with links or explanations of what type of box / enclosure and how to make it look like part of my trunk?
thanks
Old Apr 11, 2002 | 02:49 PM
spiroh's Avatar
Do you have a CL 2nd gen? What Crazy Acura did, and my first install was to create the box, and use a wall to make it look like its part of the trunk. See pics on Crazy Acura's site under his profile. 1000w each for the Max is perfect. I would use a 1.5cu ft box sealed for each one.
Originally posted by nokio
BTW
thanks
Old Apr 11, 2002 | 02:52 PM
nokio's Avatar
thanks a lot!!!
spiro, you have been added to my car idol list!
Old Apr 11, 2002 | 02:55 PM
nokio's Avatar
his isnt walled in, it looks like my bandpass box that i have now.....just sitting there with carpet.....ewwwww
how bout something like this
yes i know bandpass wont work, but just the walling off...
Old Apr 11, 2002 | 03:05 PM
spiroh's Avatar
Yeah thats how it would come out. Plus you can use a sealed box. Bsly has a bad ass install.
corybgee
ILX
28
Oct 2, 2015 07:06 PM
