CLUofI - last one, i promise
So, for two image dynamics subs pushed by 2000 watts rms, what enclosure should i do?
infinite baffle sucks, bandpass would shatter, so just have them sealed facing the trunk?
Nicky is dead on, use 1". There's only a nominal price difference between the 1" and 3/4" also. Just make sure you compensate for the difference in internal volume if you already calculated for 3/4". Make sure you use the Thiele-small parameters in your calculations. Also, I've found that some subs don't like a shallow box regardless of volume. You're gonna want to caulk the hell out of the seems on the inside too.
Do you have a CL 2nd gen? What Crazy Acura did, and my first install was to create the box, and use a wall to make it look like its part of the trunk. See pics on Crazy Acura's site under his profile. 1000w each for the Max is perfect. I would use a 1.5cu ft box sealed for each one.
Originally posted by nokio
BTW
can anyone help me out with links or explanations of what type of box / enclosure and how to make it look like part of my trunk?
thanks
BTW
thanks
his isnt walled in, it looks like my bandpass box that i have now.....just sitting there with carpet.....ewwwww
how bout something like this
yes i know bandpass wont work, but just the walling off...
Yeah thats how it would come out. Plus you can use a sealed box. Bsly has a bad ass install.
