Class D amps
Class D amps
I'm looking to replace my Hifonics Brutus. Not because its a bad amp itself but because the poor shielding of the class D circuitry kills my FM reception. I'll probably just use the amp in the TA.
Here are my requirements - Mono Sub Amp or stereo bridgable to 1ch and about 400rms x1 AND it has to have a remote so I can trim the bass control beyond the bass control on the HU.
Suggestions?
Suggestions?
1) I use the F OP of the HU for the mids and highs, and the R OP for the sub, so I can use the fader as my sub level control.
2) How about an Audison VRx 2.250.2? 560 W bridged into 4 Ohms, and a VCRDK or VCRAK control?
You need to power at 4 ohms right?
http://www.trutechnology.com/t_series.htm
http://www.arcaudio.com/arc/navigation/xxk2100prodp.htm
I'm pushing a polk mm12 with it that has the below specs
Electrical
Overall Frequency Response 20Hz - 200Hz
Nominal Impedance 4 ohms
Power Handling (continuous) 500 w
Power Handling (peak) 1000 w
Efficiency 87 dB
Voice Coil Diameter: Driver 2" (5.08cm)
Electrical
Efficiency 87 dB
InFaMouSLink
10-30-2015 09:43 AM
4drviper
09-23-2015 09:00 PM
Pegon95
09-15-2015 01:54 PM
