CD player keeps jamming
bluebullitt
Have an 03 TL-S. The CD player keeps jamming, once every week or two. It does this when I try to change CDs and gives an error code ER-E1. It will always do this if you push the CD button & then press a #1-6 button before the CD player has begun to play. I have been able to clear it by repeatedly pushing the EJECT button until it clears (have had to push it up to ~20-30 times). The CD changer has 6 CDs in it, some burned, some factory (bought & pre-recorded). They are all the same thickness, & there are no addtional stickers or labels on them. What's up??????????????
Cruising in ATL!!
well i always played burned CDs since I stopped buying original CDs long time ago. I was told by acura dealer that our stock HU wasn't made to play burned CD. I called it BS but there was nothing I could do. They refused to get me another HU since it's technically my fault for its malfunction. I ended up putting in aftermarket HU in there. So far, I'm loving it!
matty's '02TL
My TL does the same thing. Except my CD's get stuck when I'm ejecting whether or not I push any buttons at all. Sliding another CD LIGHTLY over the top of the one thats stuck gets it out.
I've got to get this problem dealt with at the dealership because buying a new HU means no more steering wheel controls.
Even top of the line head units can still fail or give you grief.......
And wouldn't we look silly using our hand held remote to operate a stereo when the controls are already on the steering wheel?
I would like to hear if anybody has successfully had a HU repaired by a dealer w/ no further problems.
This problem happens to me every once in a while. I used to go through your process - pushing eject 20-30 times. However, now it once, and the CD is out. My solution is similar to Back In Black's. Instead of using another cd, you can simply use your figure. Once you see the error code come up on the display, hit the eject button. As you hear the motor attempting to spit your cd out, press a figure against the cd slot door for a second, and your cd should begin to come out. Believe it or not, this should unjam the cd. It works on a regular basis for me and beats the 20-30 times. Try it out the next time it happens, and let me know how it works. Good Luck
bluebullitt
bluebullitt
I didn't get a whole lot of sleep last night...and maybe next time I'll remember to edit my post. I hope you realized I meant finger instead of figure! Hope it works.
bluebullitt
Originally Posted by afrikanflame
mine is shot to shit i gotta get a new one completely.
cycdaniel
12-17-2019 10:58 AM
Fool
03-10-2016 08:42 PM
09-17-2015 09:01 PM
