CD Player
CD Player
Can you guys post your Custom after market players i just want to see how it looks on inside because i want to get a custom one and the stock one is a like a brick so i am guessing it will only take like half the space the stock takes what happens to the rest of the space? Could you please post so I can see thanks in advance.
Thanks for replying my post.
I love my acura and this website
When you buy the new deck, ask to see if they offer free installation. If yes, let them do the installation to save you the trouble, plus it's free! You will have to purchase an installation kit from them if they install it for you. Make sure it is the kind with the pocket that you want because there's another kind without the pocket. If for some reason you want to do the installation yourself or if they don't offer free installation, there's a post on here about changing out the aftermarket deck. It is not hard to do at all because I have done it myself. Aftermarket deck will sound much better!
I had the same installation kit on both TL's, put the cd player in myself on both of them. It's not very difficult. Any installation kit will have the pocket because it needs to take up the space. Typically it comes with various pockets so that the one kit can fit various other models.
Also another thngs about the installation kit that I forgot to mention is that the pocket can be on the top or the bottom. I have the pocket on the bottom but I have seen it on the top so think about that and what you think is more comfortable to you.
First you need to take the wood grain piece off that is around the radio and the passenger side dash. It's just clips, so take pull it out.
You then will see the screws out around the radio unit. The rest you should be able to figure out.
holla if you got any q's
What do you mean it just clips off? is there pictures somewhere on this site or something, i looked but couldnt find it...
The plastic woodgrain is held onto the dash with clips on the back side of the wooodgrain itself. To take it off, take a flat head screwdriver or something flat and pry between the woodgrain and the dash very gently all the way around to pop it out. Be very careful because you don't want to break it. You might want to wrap the tip of your screwdriver with a thin cloth to not scratch the surface. You will see what I am taking about once you do this. But be careful, don't break the woodgrain because it will cost you some money to get it replace. Good luck!
snorf
11-04-2019 06:44 AM
Fool
03-10-2016 08:42 PM
09-17-2015 09:01 PM
