CD Player
Old Jul 21, 2003 | 10:52 PM
CD Player
If I go out and but an aftermarket headunit will i have to change out my speakers???? I've been told both yes and no so i'm coming here to the the right answer.
Old Jul 22, 2003 | 11:12 AM
shawhite's Avatar
yes and no.... ok im sorry... you can run your stock door speakers with an aftermarket headunit but you will loose the stock sub... not really a big loss... now if you were electrically inclided then you could get ahold of the wiring schematic for the tl audio system and splice a couple of wires and probably retain the stock sub... but the only thing needed to retain the stock door speakers is the 98 and up honda accord wiring harness from metra... i am not just saying this cuz i have heard that someone else did it.. i personally changed my headunit and keep the stock bloze speakers while i was saving up some more money to finish my system...i know have upgraded all my speakers and it sounds so much better....
Old Jul 31, 2003 | 03:01 PM
so if i change my headunit i need the wiring harness and i'll lose my stock sub. Also, do i need an amp b/c of the ohm difference?
Old Jul 31, 2003 | 04:13 PM
shawhite's Avatar
yes you will need the metra wiring harness (# 70-1721)... and you aftermarket headunit should be able to handle the wimpy stock door speakers.. but if you upgrade door speakers then i would suggest an amp...
Old Jul 31, 2003 | 04:14 PM
shawhite's Avatar
and yes with this wiring harness you will loose the stock sub... unless you are so inclided to do a little modifications...
Old Jul 31, 2003 | 10:38 PM
ok thanks
snorf
Nov 4, 2019 06:44 AM
Fool
Mar 10, 2016 08:42 PM
Sep 17, 2015 09:01 PM
mgbe11
1/2G MDX (2001-2013)
Sep 15, 2015 07:53 PM
MyBlackBeauty
Canada
Sep 14, 2015 05:28 PM
