Car Phone Install Questions
Old Mar 29, 2001 | 12:12 PM
oblio98's Avatar
WayTooManyAcuras
Question Car Phone Install Questions
I bought a hard install kit for my sprint phone. I checked the past posts here, and did not see one about this, so here goes.
What is the best place to get +12v for this install?
Is there a certain sequence to follow to run the wire up the windshield column for the microphone? (i.e. remove this first, etc.)
Has anyone here done a phone install and have any pointers?
THANKS!
:-jon
02 TL-S NAV w/Spoiler, Body Kit and Bowling Ball Wheel!
Old Mar 29, 2001 | 12:31 PM
Din's Avatar
Din
Post
The easiest place to get 12v is from the fusebox, use the radio or wiper fuse. To run the mic up, you can pull the a pillar and tuck the mic wire inside there so that you cant see it.
Old Mar 29, 2001 | 07:29 PM
StreetEffectz's Avatar
Post
Actually, I will tell you a really great place to get switch +12V from....remove the part of the console that has the armrest in it...underneathe is a connector for the stock power outlet...you can t-tap it right there. It's heavier guage wire which makes it a nice spot to tap from.
Old Mar 29, 2001 | 08:51 PM
preludeshfan's Avatar
Post
Street is right i used the same connection but i used the one in front because my phone kit sets to the right of the head unit. i had to get a constant wire as well because my phone kit allows the battery to be charged independently of the power for the phone. so my battery get charged all the time even when the car is off. also look for a "patch" antenna i got one and mounted it behind the tinting band at the top of the windshield because i didenn't want some crappy cell antenna stuck to the glass on the outside. my antenna sticks to the glass on the inside and nothing on the outside keeping the outside of the windows looking clean. i ran my mic wire up the driverside pillar and installed it close to the headliner so the visor wont hit it when moved forward and back.
Good luck
formerly 98 prelude type SH
Currently 2001 Acura 3.2 TL With Navigation Black/Ebony
Old Mar 30, 2001 | 11:29 PM
oblio98's Avatar
WayTooManyAcuras
Question
Street obviouly knows his stuff!
Is this the "patch" antenna you are refering to?
http://www.cellularmarket.com/cart/v...?prodID=VPATCH
Does this obscure your view out the back? Is yours mounted high on the window or low in the corner? Please advise.
THANKS
:-jon
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by oblio98 on March 30, 2001 @ ]</font>
Old Apr 9, 2001 | 01:34 PM
VTEC Animal's Avatar
Post
Better yet just use the spare line on the back of the fuse box...
http://www.acura-tl.com/ubb/Forum8/HTML/000458.html
Old Apr 10, 2001 | 05:41 PM
Post
THANKS
:-jon
&lt;FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial"&gt;[This message has been edited by oblio98 on March 30, 2001 @ ]&lt;/font&gt;
Yes it is very similar to that
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
lland
Oct 4, 2015 04:47 PM
datadr
Sep 2, 2015 06:46 PM
