Car Audio basics, or, SQ for noobs
#41
Still here
Originally Posted by elduderino
So are you saying it's easier for the user to make that mistake?
This is about the clearest description I can give you on this:
from:http://www.carsound.com/UBB/ultimate...=019131#000000
Originally Posted by Richard Clark
gee guys-------this has to be about the 2 millionth time i have tried to cover this subject-----a search in the archives will provide some good info from when i had a little more time to actually cover this dead horse----- but to cover what rob has already well explained-------it is another one of those voodoo beliefs that will always haunt the audio world that underpowering a speaker has any negative effects EXCEPT for the simple fact that if the speaker is underpowered it will not play as loud--------what happens if we underpower a race car??????----it does not go as fast-------does it cause the car to crash???--i think not-------what happens if we underpower our toaster?????-----the toast does not get as dark-----there are idiots that would have us believe that the toast would be burned-------imagine trying to explain that to your family-----gee i turned the thermostat on the toaster down and it burned the toast------are we forgetting that wattage is a measure of power and in electronics power is directly related to HEAT and it is HEAT that BURNS up voice coils ------ underpower a 200 watt speaker with a 10 watt amp and what happens???????the speaker will play about 10 dB less loud and distort if you try to play it any louder than a 10 watt amp will drive it--------will it hurt the speaker?????------lets look at the facts and forget the pleadings of the technically ignorant-------that 10 watt amp when driven into total clipping will likely put out about 20 watts of really distorted audio-------and that 200 watt speaker will just lap it up like a thirsty dog and last nearly forever till the sunlight rots its cone out or you can afford a larger amp---------there are only two kinds of people that believe underpowering a speaker is damaging------the technically uninformed or the totally ignorant------which one are you????????............RC
#42
running a larger amp rated at or above the wattage of the sub can and probly will damage the coil from heat.
as for adjusting gains i would say that people who firstly buy a wallmart amp and crank the gains and also buy wallamert subs are far more likely to blow shit up then people who have the money and some common sence to buy the right equipment and know how to use it correctly. or at least get it installed by smeone who knows how to.
i think from my experience common sence and ones income and spending potential go hand in hand. if your generrally stupid person you probly dont have the capacity to earn a whole lot of money.
disclaimer, if you dont have money right now its not because your stupid. sometimes people have tough times in life.
#43
#44
VP Electricity
1 Post
I was not trying to blame amps, and I was not trying to say that speakers fail due to being driven at low wattages. I have never said that speakers blow up with low levels of undistorted power, so if you're arguing that point, it's kinda off-topic. Look, I don't care if it IS Richard Clark, he's talking about an amp that is NOT clipping and I am talking about an amp that IS clipping.
As far as the fault of the amp, e_lectro, I have never been trying to blame the amp - I've simply referred to what is easier. As in more likely - happens more often in real life.
This is kind of a circular point - if stuff is installed so you can't blow it up, then you can't blow it up. We all agree about that.
That doesn't mean that it's not easy (or easier) to install it where you CAN blow it up. Of course it is!
Is it easier to drive a speaker with a clipped signal using a small amp than a big amp? Is it more likely to happen? Yes or no?
Yes, it is easier - regardless of what you want to blame it on - gain setting, etc., the base question is, is it easier, and the answer is, yes, it is. Doesn't have anything to do with the shape of the distortion curve or the quality of the amp - smaller amps by definition go into clipping with fewer watts of output than larger amps, and people are more likely to have smaller amps, just judging by the sales figures! I don't mean TINY amps, I just mean lower than the speaker power rating.
And this discussion is still discounting HU deck power and OE amps that have no gain adjustment, but are preset at the factory. Placing lower-efficiency speakers in such a system with higher insertion-loss crossovers means that the user is going to ask for higher volume settings to reach an acceptable volume level, and with that amp, he is more likely to go into clipping, since it's small. Blowing a speaker is thus more likely to result, even though the smaller amp is below the power rating of the speaker used.
The intent here was to warn people that they should not expect installations to be problem free just because they bought speakers with higher ratings than their amps have. This is a common question/complaint/issue on the sales floor, on forums, and with DIY shadetree installers, and the EIA/CEA was trying to come up with a way to commmunicate this to consumers back in the early 90's - and simply saying "it's not the amp's fault" was not considered an effective way of communicating it to the end user. The industry was trying to decide how to deal with this problem back then, and I don't think they've figured it out as an industry, because the biggest complainers as suppliers were the worst offenders when it came to using speaker wattage ratings as a marketing tool.
#45
C) The speaker is sent distorted signals, which it can't play, but which end up melting the motor assembly or causing the speaker to rip apart. This is usually caused by the amp “clipping”, or running out of power.
It's easier to blow up a speaker with a small amp than a big amp. This may seem backwards - but the simplest analogy is, if you ask a 40-watt amp to play 80 watts, you will get 40 watts of music and 40 watts of distortion, and distortion blows speakers faster than anything. It's a bit more complicated than that, but as an analogy, it's workable.
Well, those were my Ten Basics of Car Audio. Read them, learn them, live them, and you can learn anything you need to about good sound in your car.
you had no proof to back this statement up and we have proven that.
#46
again dont contridict yourself.
and when you asked me to explan how a 15WPC head unit blows up a 200 watt speaker
you were referring to exactly the same scenerio were you not?
#47
VP Electricity
1 Post
Originally Posted by Bass Mechanic
Eludo this is what you typed this is what started this discussion. you made an incorrect statement. stop trying to twist the facts of what you said all around. stay on topic and lets move on shall we?
What I said stands. It's a pretty good description of a clipping amp. If you don't like the analogy, make a new one, but it's a good description of a clipping amp.
#51
'05 TSX SSM/EB/AT/Nav
Here are some questions that the answers will help me form my opinion on the subject:
50watt amp and 200watt speaker:
In this case the 50watt amp peaks at 100watts and therefore no matter how bad it’s clipping, it can’t hurt the speaker. But, you would get low volume that would distort before desired volume. Sustained play could damage the amp, but not the speaker.
150watt amp, and 200watt speaker:
In this case, everything is great until clipping occurs where the amp could spike to 300 watts and damage the speaker. The chances of clipping are still likely due to desired volume level, so this is a dangerous setup.
200watt amp and 200watt speaker:
This case is similar to the above only a higher volume can be attained before clipping occurs, so under normal conditions, this is safer. Arguably this may be the safest setup even though the amp could still be driven to clip which could send 400watt spikes.
300watt amp and 200watt speaker:
In this case, the amp could blow the speaker when producing a clean signal. However, it would not be as likely to blow the speaker quickly since clean signal is not erratic like clipped signal. The clean signal would distort the speaker in a fairly controlled manor, so unless the user didn’t know or didn’t care distortion was occurring, it would be fine. However the user that would turn any of the systems up all the way will blow this one the quickest. But on the other hand, this system would be able to deliver the maximum undistorted safe signal. So for that reason, this may be considered the safest setup (depending on the user).
For me personally, I think #4 would be the best. I would never need to worry about clipping, and would be able to back off at the first sign of distortion while being able to maximize my speakers.
For a person not concerned with sound quality, I think #3 would be best. They have the lowest chance of blowing things if they tend to only go for desired volume regardless of quality.
- Can an amp send more than its rated peak power when it is clipping (I already know it can exceed its RMS rating)?
- Does the output level continue to increase as distortion/clipping increases, or does clipping already infer max output has been attained?
- Can you make any amp clip?
- Is a low build quality amp more likely to clip than a high build quality amp?
- Can an amp send direct current when it is clipping?
- Is it likely direct current will damage a speaker?
#52
its literally being told to move to the forward position and hold it there then sweep back to the rearward position hold and repeat. this combined with the fact that the springiness of the suspention of the sub trying to move the cone back to center will also cause the coil to generate excess heat. the key here is the sub has to move to cool itself
here is a simple analagy if you had a coil sitting in free air and no magnet or movement involved it would generate the same heat or dissapate the same watts wether the signal was sine, square or triangular or any other type of signal even DC. the measure of watts is simple the voltage times the current = watts or in ohms law P=I*E the signal matters not. but to understand why it would get hotter under a clipped signal is simply because of the fact that if there were no movement of the coil at all that same 200 watt coil would probly smoke at 50 watts or less because it doesnt have the ability to dissapate heat unless its moving.
if you limit its movement with a clipped signal and the fact that the sub was not intended to stop on a dime and reverse direction much as a square wave would cause it to it will A. not be able to cool as well and also generate more heat then in normal operation. the watts havnt changed any it just lost its ability to stay cool when air is not passing over the windings to keep it cool.
2. yes any amp will clip wether it be the the signal to the preamp or the preamp to the power amp (internally) in other words you can get a clipped signal by running more input to the amp than the preamp can handel or turning the preamp up so high that it will take a clean signal and clip it at the input of the power amplification stage. how easy it clips depends on the gain value of the transistors of the amplification stage your asking about.
a clipped signal is notheing more than an over driven signal or one that causes the transistors of the amplifier to reach their full "ON" state in a push pull configuration amplifier 1 transistor turns on to send current to the sub in a forward fashion where the other compliment transistor turns it on in a reverse direction.
without trying complicate things assume an amp has voltage rails in the output stage of + 20 and - 20 volts with respect to reference 0 the speaker outputs will be able to send no more than 20 volts + or - to the sub no matter how large the signal is. if you exceed this limit the signal stops at 20 volts when if the voltage were higher it would have continued so you get a straight DC situation breifly while the input signal swings all the way positive and then starts back to 0 again and the same on the negitive side.
in other words you could also cause an amp to clip with the same input signal if you could adjust the power supply voltage to the output stage. thats why unregulated amps have a higher wattage rating at 14.4 volts then they do at 12 volts as is stated by many manufacturers (ex 150 watts at 12 volts 175watts at 14.4 volts.) with the lower voltage the amp would clip sooner with the same input signal. and as a result its wattage output stops right there at 150 instead of 175.
3. it's possible but you cant blanket statement that because it depends on the input sensitivity adjustment and the gain of the transistors themselves. but the answer is really relitive to the watts in this example.
if your asking me to compare 2 amps 1 at 25 watts and one at 250 watts if both have an adjustment sensitivity between 200 mv and 2 volts with a 2 volt signal applied they would both clip in theroy at the same setting provided the adjustment knob on both amps was actually that accurate.
if you hooked a 4 volt signal to both examples you would clip the amp on its lowest sensitivity (2 volts) at about 1/2 volume again assuming the controls were that accurate.
4. yes in a mannor of speaking it is DC but only as long as it takes for the signal to return below the limit of the voltage rails. assuming you played a 60 HZ signal severly clipped the duration you would be sending dc to the sub would only be for about 1/4 of a cycle in each direction of a 60 hz signal so about 25% of the time it would be getting DC and it would still change direction 60 times a second. i am too tired to figure out how long that is in seconds but ltes just say its very very brief and far less than a fraction of a second
5. direct current will definitly damage a speaker. as in if you put a battery to it it would only take a few seconds of straight DC to smoke the coil because there would be no movement of the coil to keep cool. of you applied 20 volts to a sub of straight DC on a 4 ohm load the watts would be 80 watts and no moving air to dissapate it. 80 watts is pretty damn hot imagine grabbing an 80 watt light bulb while its been on for a while to get the glass temperature up to the full 80 watts worth. yea without cooling that would definitly smoke a coil.
hope this helped clear things up
i dont think i numbered thoes right but i think you can get the jist of it.
#54
VP Electricity
1 Post
OK, in an attempt to get past personal disagreements and come up with text for C) that doesn't involve deciding whose is bigger, I submit the following:
(Note: The added text is in italics. I don't think these contradict each other, but they address problems that have been brought up and hopefully cause everyone to feel like Barney the big purple dinosaur).
C) The speaker is sent distorted signals by an amplifier being driven into clipping, which it can't play, but which end up melting the motor assembly or causing the speaker to rip apart. This is caused by the amp running out of clean power. Every amp can put out more power than it's rated - the power rating indicates a point where distortion is acceptably low. Many amps have a THD output graph on the box - watch how it climbs with output wattage!
Some people believe that it's easier to blow up a speaker with a small amp than a big amp. This may seem backwards - and is not because speakers blow up with lower amounts of clean power - they do not - but the simplest analogy is, if you ask a 40-watt amp to play more than that, it can go up to 80 watts, but the amp will clip and send DC in its output and also assorted high-frequncy distortion. This may cause the speaker to blow up due to overpowering, or due to overtraveling due to the DC signal shoving them too far (tweeters handle DC the worst, but mids or "full-range" speakers in the door don't resist overtravel very well, not being in an enclosure that helps them do so, and woofers in ported boxes also do especially poorly at resisting overtraveling with a clipped signal input). In addition to this, some 12V audio professionals* have seen some speaker designs, especially mids and tweeters, which seem to react poorly to odd-order harmonic distortion generated by clipping amplifiers.
As a result, please don't assume that just because your amp is rated to put out less wattage than your speakers are rated to handle, that you can't blow them up. You can.
This text replaces this: Some people believe that it's easier to blow up a speaker with a small amp than a big amp. This may seem backwards - and is not because speakers blow up with lower amounts of clean power - they do not - but the simplest analogy is, if you ask a 40-watt amp to play more than that, it can go up to 80 watts, but the amp will clip and send DC in its output and also assorted high-frequncy distortion. This may cause the speaker to blow up due to overpowering, or due to overtraveling due to the DC signal shoving them too far (tweeters handle DC the worst, but mids or "full-range" speakers in the door don't resist overtravel very well, not being in an enclosure that helps them do so, and woofers in ported boxes also do especially poorly at resisting overtraveling with a clipped signal input). In addition to this, some 12V audio professionals* have seen some speaker designs, especially mids and tweeters, which seem to react poorly to odd-order harmonic distortion generated by clipping amplifiers.
*(not me!)
#55
dude, give it a rest! now you just not making any sence at all. you contridict yourself in every attempt you have made to save face.
i already pointed out the facts. how about you just copy and past the facts of what has been spelled out for you and stick it in your sticky.
#57
So if there is anything to be learned here... you should not under or over power your speakers. Underpowering will make your amp sound bad, and overpowering will make your speakers sound bad, and either to an extreme can blow something.
#60
hi guys, interesting discussions. a couple of points only, of the many subs I and amps I have used, I have only blown two: one through massive long term abuse (a jl 8w1 in a microsub box, rated at 100w continuously) driven by a 300 w Rockford amp for over three years, the second because it was totally crap (rockwood? amp and some swapmeet $29 special sub). Typically I drive my subs (reputable brands) with a lot of power (reputable brands). No problems due to professional installation and reputable brands.
The other issue I am interested in hearing your opinion about is soundstaging and imaging. I am a nut when it comes to those two issues. At present I have a set of dynaudio seperates in the front doors, time aligned using my alpine head unit and no rear fill. I am interested in changing out the door speakers for a set of dynaudio 3 ways installed in the doors/kickpods and no time alignment. Has anyone done anything similar? Thanx, jps
#62
mounted co-ax style in the grill, although in my last car (02 GTI) they were mounted in the stock position, actively x-ed over and time aligned by themselves. jps
#63
VP Electricity
1 Post
There was a poster who PM'd me about building pods in the TSX with a 6MT... looks awfully hard to do in a 6MT daily driver to me. Hope he sees this...
I have not done that setup. That said...
I assume the dyne 3-way you are talking about is the dome tweet/dome mid setup. Since you have the latitude, I would make the following suggestions:
Consider buying the Dyne drivers seperately rather than the 3-way kit. This allows the following:
1) You could go with the bigger tweeter. In a pod a slightly larger tweeter is irrelevant, so consider the MD130 tweeter over the MD100, or even the Esotar if you have the cash.
2) The Dynaudio 3-way passive xover is not very flexible as I understand it. They cross the tweeter over at 4K and the mid/midbass xover is at 700. This range is not quite 3 octaves, and the passives are almost undoubtedly interfering with each other to some degree (passive crossovers work by increasing the impedance at and above/below a given freguency at an increasing rate.) I have made lots of 3-way passive xovers and I don't think they are the end of the world, but if you can, I would use a seperate set of amp channels for the midbass than for the mid/tweet, and use an electronic xover at 700 Hz or so.
This leaves the xover for the mid/tweeter (edited for error). Dyne crosses over that tweeter at 3K with a cone midbass, but at 4K with a dome midrange (the midrange can obviously play higher, and in a pod there will be little straight-line "beaming" at higher notes to worry about, since they are pointing at you). The best result would be to build custom passives for these at 4K, I suspect - Dyne lists no 2-way crossover at 4K.
Since Dyne's xovers are somewhat off-the-shelf anyway ( they use the same xovers regardless of which cone mid you are using, or whether you have the MD100 or MD130 tweeter - and we know they aren't identical) I think you might be best off by designing your own passives for the mid/tweet crossover. Time alignment between the two should be irrelevant, as the mid and tweet will be on the same plane. You may at some point go with time aligning the mid/hi output with the midbass door output, and that would work out OK with seperate midbass and mid/tweet channels.
The pod setup would allow easy tinkering with the passive component values if you stash them inside until you nail them down for good - good news for an imaging nut : )
#65
not sure which alpine HU you have, but if you got the 9835, why not just use the xovers on that instead of building some passives? active > passive. i believe most alpine headunits that have time alignment also have a 3/2 way xover. as for kicks, good luck. its going to cost you some money to make some kicks for the tsx as the hood release and fuse box is in the way.
#66
VP Electricity
1 Post
Hey, tuan, if it has a 3-way active xover, I was assuming he would need a 4-way total - tweet/dome mid/cone midbass/woof.
Unless you were proposing that he use an external xover with the subs? I think that that would be a fine way to do it if you didn't want to do time alignment (which you said you were willing to let go of).
If you wanted to do time alignment, I assumed that you would need to use it in 3-way mode and high-pass the pods...
#67
Boom goes the Dynamite
So how is it that a head unit stock or aftermarket can blow speakers if there is no gains to adjust and it isn't being over powered/under powered?
Do I hear distortion?
#68
-S namyaC-
I would like to add my two cents into this. This subject is much debated in the pro audio world. I think Mega made a good list of questions, and I don’t exactly agree with Bass Mechanic.
1. Yes, square waves are approx. 2x as powerful as a respective sine wave of the same amplitude. The crests and troughs of the wave are now much shorter resulting in an almost constant time the amplitude is applied to the voice coil. Bass Mechanic is partially right; the measured power (well easily measured, like with a multimeter) would be pretty much the same. This measured power is the amplitude of the “wave”. However with a sine wave, the amplitude is held for ~25% of the time. Simple measurement alone is not valid here.
2. Clipping is referring to the amplitude rising and reaching the limit of the device. The wave will continue to rise and the crests/troughs (IE tops) of the wave will become chopped off. At the onset of clipping, the overall power difference isn’t that great. It does indeed rise as more and more of the wave is chopped off, up to the point it becomes a complete square wave.
3. Any amp with it’s limiters removed, can be fed a signal that in conjunction with it’s own internal gain, will surpass the maximum input of the amplifier and will clip the signal.
4. Yes and no. Taken off the shelf, a high quality amp generally can produce more raw power. However; gain, power output, etc equal; neither will clip sooner than the other.
5. Again, yes and no. Technically a straight square wave is stepped DC, it changes the direction of current in a regular pattern, that pattern is determined by the dominant frequency at the amps input stage(s). If you send the amp a straight 80Hz sine wave and run it into hard clipping, it will basically turn to DC and reverse polarity at a rate of 80 cycles per second. However, it’s rare to reach that situation in reality.
6. Again, yes and no. This is dependent on the current available to the speaker. In Bass Mechanic’s example of a car battery, it would more than likely damage the speaker. The car battery can supply much more current than the driver can safely handle. However, hooking a simple 9v battery to the speaker will cause no damage at all as it doesn’t have enough current. It will simply hold the voice coil out (or in) until the battery runs dead.
The examples below are extremely good examples!
YES! As long as the potential power output of the amp does not exceed the capabilities of the driver, it will not damage it, only sound like crap.
Good example of a basic under powering situation. However, as long as the amp nor anything else in the signal chain is allowed to clip, it will not damage the speaker. Volume will be lower than driver can produce.
This is the basic “safe” powering assumption. As long as the amp or anything else in the signal chain isn’t allowed to clip the signal, no damage will be done to the driver. The driver will reach it's RMS rating, but not it's true potential. However, there is really just as much danger, if not more, in this setup as the underpowered setup if it is allowed to clip.
This is safer, yet still not exactly what we should shoot for. The problem is there are too many “fluff” specifications given by manufacturers today. The only power rating of a driver we should be concerned with is the RMS rating. Good powering would be 2x the RMS rating of the speaker. This provides enough power so that peaks are not allowed to clip the amp (IE headroom). These peaks are easily handled by the driver if it’s clean power. This requires someone who knows what they are doing else it can do more damage than any of the other setups as it can hit the driver with 4x it’s rated power.
#74
El Duderino's Ten basics of Car Audio
Pegon95
08-31-2015 02:18 PM
